We have a 2016 Elddis on a Boxer base. We have had problems in the past where the hab door wouldn’t lock with the key fob. We managed to fix that with help from here, it was a break in the cable. When the same thing happened we assumed same fault and recrimped the broken wire. That seemed to do the trick. However it now seems to be something more complicated as all wires appear intact. We get the correct sounds as if door locking when we use both the fob and using the key in the van doors. However, the door will not lock with either. It isn’t possible to lock it manually from inside either as the small grey push button thing will not depress. I have tried to add a few photos to show the type of lock. Can only presume something is physically wrong with the locking mechanism inside the door.
Any ideas for a fix? Could do with it fixing as driving back through Spain and France towards home in a week so need to be able to lock the van. Thanks.
