Grey water tank cleaning (1 Viewer)
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
The tank is under the floor with no access. Smells coming through basin and sink plug holes. Any recommendations please as to best cleaning solution to use bearing in mind I can only pour it down the sink.
Al-Di
3,060
28,862
prestwich
Eura Mobil A Class
since 2013
soda crystals in hot water, half fill tank then go for a drive with lots of bendy roads & drain, may need to do a couple of times,(y)
Oct 20, 2010
2,248
37,617
Burry Port South Wales
Since 2003
Cheap Lidl coke, pour a few large bottles in empty tank take it for a drive to swill it about, flush it with clean water after. (y)
Cheers
Ed
R
Robert Clark
We tried Coke and soda crystals with little effect, then we tried Dish'n'treat which is a special washing up liquid which, when used once a day keeps pipes and tank smelling sweet. It dissolves and prevents grease build up and kills bacteria.
Oct 18, 2014
1,858
1,157
Salisbury
Hymer B598 PL
I use a small amount of the elsan stuff into the waste pipes via sink holes each time empty out & fill up the fresh water. That seems to keep smell bugs away whilst travelling.
In between travels leave waste open so it drys.
If already smelly cheap Coke does work.
Brisey
Sep 4, 2007
8,087
17,512
Sutton on Sea
Since 2003
We use the cheap coke method and find it works as well as the proprietary cleaners.
11,843
14,080
The cheap coke from any supermarket. For some reason the one with sugar in seems to work better than the diet version. Bung in about 6L putting it down all the drains, nice bumpy drive, leave for a few hours and drain. Gets all sort of muck out.
sedge
Jul 7, 2009
5,504
13,121
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
Urban drives are ideal for the cheap coke treatment, on roads you normally avoid cos of all the speed bumps!!
C
Jul 10, 2014
179
57
Cheltenham
Elddis Encore 255
3 years
Thanks all. It will initially be a cheap coke treatment. No problem finding a bumpy road, around here it would be hard to find a smooth one!. Then regular Dish'n'treat will be the plan.
R
Robert Clark
Once you've started using the Dish'n'treat you'll ever have a smelly tank again - sorted !
Oct 30, 2010
4,256
20,707
Suffolk or France or ........
A Class Carthago Chic
Since 2008
Yes you use it just like washing up liquid
We didn’t need to use it every wash - we found that just once a day was sufficient
Quite expensive for a washing up liquid but if it stops that pong when we dump it will be worth it.
I give our grey tank a good jetting out with a hose a couple of times a year but it soon starts to pong again.
About to order some from Amazon.
Jan 8, 2013
8,491
11,530
Dronfield - Derbyshire
Burstner Lyseo 690G
Happy FLT since 2011
What! - you wash up more than once a day??
It seems to me that even after you've cleaned it, once you've half filled it again it stinks just the same. Ongoing daily treatment might be the way?
Thanks for that.
Duck Truck
1,203
1,226
UP North
Hobby 725
Take one small toothbrush
and one small child.
drop them into the tank with a promise of sweets later
Jan 8, 2013
8,491
11,530
Burstner Lyseo 690G
Well I've just bought some from Ebay £9.99 litre ---- and this weeks trip to Scotland should be a good test.
I've put it in the washing up liquid dispenser so it will dose the tank when we wash up. I'll let you know how we go on.
23,836
72,543
We use a couple of litres of pure orange juice... Pour it in before a trip... By the time we get where we are going it has all sloshed around and have no smells at all
