Grey water drips
Brbzzz
Burstner TD 644 GL
Unless I am completely level there is a small drip from my grey water pipe. The lever works that is to say the contents of the the grey water tanks empties in a gush as you would expect but water still seems out when the valve is closed. Burstner 644 GL.
:hiya2: w2f
Ours does too for a few seconds after the valve is shut. Just the pipe emptying. Does it continue to drip for a while?
Oh no,not a grey water post.? :rofl:
Seriously, probably the valve needs a clean,just disconnect it ,take out the valve and clean it. (y)
Same problem, I have fitted a pvc lever valve in the discharge pipework and left the original valve in - situ and open. Tried to remove the original but failed.
Robert
Simply move a little back from fully closed - it usually works. I don't know why :Eeek:
It drips worse when the tank is full -ish!
