Bigbass
- Jul 26, 2020
- 30
- 68
- Elddis CV 60 Chatsw
- 5 years but tent camper previously
Just back from the fourth post lockdown trip with a new Elddis CV60 and had grey water drain problems from day 3, very slow run out, like 10 minutes!! Took off the grey tap following suggestions on the Forum (thanks) and found a plug of grey swarfe from the tank drilling in the pipe and tap, the larger pipe is a push fit on my van and run-off improved. Drained off over the service point on Saturday and thought empty but got home and after the M6 shake up, emptied another 30 litres out of the 70 litre tank. Removed the larger pipe again this morning and flush out with a hosepipe and out came a disc of plastic from the hole cutter. Bit more attention to detail needed Elddis!!! or should it be the dealer??
Drained the fresh water tank and out came another piece of swarfe, fingers crossed it has not got into the heater or pump.
Passed the info to a few people on the sites with similar vans after the first issue but may help a wider Forum..
