View attachment 901812I gave this type of tap fot grey waste anybody know how to take apart as its very stick and whole pipe swivals too
We have a similar tap albeit fitted to what looks like a narrower pipe than yours. It is just a compression fitting so you just pull hard, twisting it a little as you pull.View attachment 901812I gave this type of tap fot grey waste anybody know how to take apart as its very stick and whole pipe swivals too
Ok thanks , just didnt want to break in my hand lolWe have a similar tap albeit fitted to what looks like a narrower pipe than yours. It is just a compression fitting so you just pull hard, twisting it a little as you pull.
Hope this helps.
Thank youJust pull and twist it off hard. Once off, remove the internal baffle to get much quicker drainage.
See this thread -
Bailey Advance slow to drain gray
So reverse your argument about getting Baileys fixed on the continent and you could say "try getting a Morelo fixed in the UK". I am merely saying that for the number of Motorhomes Bailey produce yearly they are no worse than smaller output manufacturers. In fact for the price asked they offer...www.motorhomefun.co.uk
