canopus
My missus will have a dickie fit if I mention more expense.
Think I’ll give these a miss David man maths or not.MorningStar MPPT solar controller the best available although not cheap, superior charging programs with temperature compensation
30amp model should be good for your needs
https://www.morningstarcorp.com/products/tristar-mppt/
plus your going to need the display meter
https://www.morningstarcorp.com/products/tristar-digital-meter-2/
Yeh, but!if you have an AES fridge with a S+terminal it tells the fridge to switch to 12v when batteries are charged and you have excess solar.
It's OK Ken will have a proper old fridge like ours with just the D+ so if he does the fiddle with a diode then it will work in the correct sequenceYeh, but!
Give them a good charge on hook up, then the simple test of a known amp load and keep an eye on the voltage for how long they last then the maths is pretty simple,Might need to discuss the fridge option with you Martin. At the moment I need to establish if my batteries are on the way out. Do I buy new ones plus an mppt controller plus any other necessary kit to give optimum performance.
I’ve definitely discounted AGM batteries.
Ah, oh for those steam versions!It's OK Ken will have a proper old fridge like ours with just the D+ so if he does the fiddle with a diode then it will work in the correct sequence
Martin
120watts of bulbs will be 10amps, 10amps for 10 hours = 100ah so a 200ah bank should still be above 12 volts at the 10 hour point.
Martin
...gel batteries are the type of batteries used in mobility scooters "they are not full of jelly?" they are lead acid but have a fibreglass filling between the plates inside the battery to hold the acid sill so it wont slop around and are sealed so they cannot be toped up or spill any acid if turned over, this type of battery is also called a "leisure battery" it is not designed to be an engine starter battery that gives a heavy discharge in one hit but to give a steady discharge over many hours down to about 30% remaining amp hours left in the battery if you try to take any more out of the battery it will "kill off the battery" as for a "lithium battery" forget all about them! you need a special "three stage" battery charger to recharge them and the price of the battery is nearly three time the cost of an AGM or GEL battery, both AGM or GEL use the same battery charger by the way,, it is a special charger so,, ""DO NOT TRY TO RECHARGE THEM USING A CAR BATTERY CHARGER"" the volts on a car battery charger are far to high to recharge an AGM or a GEL battery (max recharge volts are no more than 14.5 volt's for bulk charging and 13.5 volt's for float charge) a car charger could be pumping out 16+ volts!,, if your van is fitted with 80 amp hour batteries AGM or GEL and you change them to "normal car batteries" (lead acid) they type you can top up with (distilled water) you may need to change your battery charger inside the van as it wont fully recharge this type of battery but a normal car charger will be fine, and the new car type batteries will be half the price of AGM or GLE, but a word of warning,, you will not get the same length of user time out of car batteries as you must not knock the batteries out to more than 50-60% charge rate or the car batteries will go into ""supper discharge"" and they will not recover from that, no matter how long you re-charge them, so to slim that lot down,, you can replace your old batteries with AGM or GEL and get the same performance that your getting or go for the cheaper car batteries and change the battery charger but get a little less performance as a little less cost? DO NOT GO FOR LITHIUM BATTERIES!
I think you confuse AGM (Absorbent glass mat) with GEL (Gelified ELectrolyte). https://en.wikipedia.org/wiki/VRLA_battery#Gel_battery
Lithium was invented in the 70s, and current leading battery technology in electric cars, phones, tablets, PCs, portable speakers, solar systems, clocks - almost everything we consume which is battery operated. About lithium in motorhomes:
Until now, mostly the most expensive motorhomes have been offered with lithium options, but now you also get it as options on the more normal motorhomes: Broken Link Removed
In a few years, my guess is that lead acid is something we all laugh about, how everything was so terrible "in the old days" - had to charge slow (charging lead acid to 100% takes many hours - 12-24 in many cases), heavy batteries, big, and relatively short lasting. Lower operating voltage on the lead acid, and you need a few batteries to be able to run a big inverter to power ie a microwave, coffee machine etc. Lifepo4 can draw really big currents with ease, even smaller batteries.
The most used lithium chemistry used in motorhomes use more like a two stage charge pattern: Constant voltage and constant current (CC/CV). Given you get a lifepo4 battery which is meant for 12v / motorhome / boat / leasure use, it's not strictly needed to replace every charging system you have onboard. But to get the famous fast charging that lithium supports, you need to do some other investments aswell, depending on what you have onboard. IE my solar charger (Victron Bluesolar MPPT 150/70) supports lithium charging, and tests reveal that I would get a hefty lot more power from my panels using lithium as a battery, as charging doesn't have to be limited to the little amount the lead acids supports. But my EBL stops at 20 amps and has no charge program optimized for lifepo4, so charging using this will take time (but faster than lead acid), but it works. Also, charging from the engine's generator currently goes through the EBL, meaning the same 20 amps limitation. There are combi-chargers which remedy this. Ie the Votronic Battery Charger VBCS 60/40/430 has a 60 amp DC DC lifepo4 charger which works fine with most modern motorhomes' generators, as well as 40 amp charging from the mains, and supports 430 watts solar system. There are different sized models for different needs.
I agree it's not as simple at slotting in any old (or rather new) lithium battery into your motorhome, but either if you read up about the subject and select a product that suits your needs (and you current charging system if you're not ready to upgrade), or go to a well known supplier and get help, if you want to go down the Lithium path.
In my latest motorhomes I've selected not to go for lithium mostly because of the price and how long I'm thinking of keeping the current motorhome before selling it. But I'm seriously dribbling on a lifepo4 battery at the moment.
Havnt read every post on this so apoligies if its already ben answered.
OK now i have agm leisure batterys but a wet engine battery so what do i set my solar to as it feeds both batterys, do i set it to gel and risk frying the engine battery or flooded and risk not charging the gels?
What plonker told that load of BS. It is only the charging voltage that is higher.Old 110 amp lead acid battery although topped up and on cons. So am changing to a 100 amp AGM which I have been advised will provide a higher voltage which will cure the fridge problem.
You don't say how much solar you have but I assume around 300 watts?Naturally the people selling the battery!
So if the regulator only lets 10 amps out are you saying that replacing the present lead acid battery with an AGM battery will not help us to solve the problem with the fridge not being charged by the hab. battery?
Cheers,
Saltings
