Just a quick one how easy are gaslow systems to take out and put back in. Thinking of taking ours out and putting normal bottles in for the season. Is it a DIY job. Or do you need a gas fitter?
Why would you want to do that? It's easy to take them out and replace as I have done it on Van's but wouldn't want to just take them out to replace with calor for "the season",just cant see the point or am I missing something.?Just a quick one how easy are gaslow systems to take out and put back in. Thinking of taking ours out and putting normal bottles in for the season. Is it a DIY job. Or do you need a gas fitter?
?he is working on a site probably doesnt want to move the van
Like others have said ..... why? Much cheaper for autogas.
You can use one of these to connect a calor cylinder to your Gaslow filler point
Do I just need just that. As has been said we have parked up for the season due to work and it would just to much like hard work to go and refillOoooh Clever idea! ?
Does that mean that if you had empty Gaslow bottle(s) that you simply plug in a Calor bottle and you can run your cooker/heater/fridge from the external Calor Bottle ?
Would the Calor gas try to fill one or both or the Gaslow bottles ?
For £18, that sounds like a bit of kit any Gaslow equipped vehicle would want as an emergency back up
YesOoooh Clever idea! ?
It’s all you needDo I just need just that. As has been said we have parked up for the season due to work and it would just to much like hard work to go and refill
You should have said that in the first place.Do I just need just that. As has been said we have parked up for the season due to work and it would just to much like hard work to go and refill
You will need the local cylinder connection hose 01-4500 then one of the cylinder adaptors which for a Calor Propane cylinder is 01-1674 .Do I just need just that. As has been said we have parked up for the season due to work and it would just to much like hard work to go and refill
Sorry didn't know you could get stuff like that. New to this. I was thinking I would need to change the bottle. Will ring gaslow tomorrow and sort one out.You should have said that in the first place.
Use the same hose for connecting ours to spanish bottles when parked up in Spain.
It's an easy job, but like anything else - easy if you know what what to do.Just a quick one how easy are gaslow systems to take out and put back in. Thinking of taking ours out and putting normal bottles in for the season. Is it a DIY job. Or do you need a gas fitter?
Gasit also do the same hose as well and you can pick them up in most motor home shop outlets where they sell refillable kits.Sorry didn't know you could get stuff like that. New to this. I was thinking I would need to change the bottle. Will ring gaslow tomorrow and sort one out.
Thanks for all the help
Jim, I can't find one of these on the Gasit website. Do they call it by a different name.Gasit also do the same hose as well and you can pick them up in most motor home shop outlets where they sell refillable kits.
Connect it to the filler pointDo you just connect it to fill the gas or do you use it like a third bottle
According to Gaslow's website you use it once one of your existing bottles are empty. It does not fill the existing bottles with LPG, instead it gases off in the new bottle and the gas passes through the existing empty bottle and into the regulator.Do you just connect it to fill the gas or do you use it like a third bottle
You connect it to the fill point as above and use like a third bottle, one of your refillable needs to be empty. We just keep one refillable bottle closed usually and change the 3rd bottle which sits outside the van.Do you just connect it to fill the gas or do you use it like a third bottle
I bought mine from a gasit stand at a Peterborough show along with 3 continental adaptors. Its a rubber hose with a connection for a calor, Spanish adaptor bottle and a UK filler end. Works a treat.Jim, I can't find one of these on the Gasit website. Do they call it by a different name.
You really don't want to leave your van parked up for more than a few weeks to keep it in good order it needs a good drive every few weeks to get everything up to operating temperature.Do I just need just that. As has been said we have parked up for the season due to work and it would just to much like hard work to go and refill
