Hello, we hope all is well.
Was time to replace our gas regulator, a Gaslow regulator with gauge, although the gauge had not worked for some time, but maybe the gauge just needed adjustment, was just wondering if anyone else has a similar device with Gaslow gauge and is aware of gauge adjustment as no mention of adjustment in the user instructions.
The issue, was the gauge was reading full green, meaning great gas pressure, however, was always reading green, even when on the bench connected to nothing.
A shake of the gauge reflected internal movement, so we decided to dismantle and investigate.
Please see attached where we have removed gauge from regulator and rigged the gauge to a maual pump with release valve.
Initially, the pump seemed to be having an effect, but the gauge was reading wrong.
We then discovered the transparent case of the gauge rotates, so we rotated the gauge to reflect red i.e. no gas, then operating the pump, released the valve and all appears well with the gauge red to green to red as expected.
We have instructions for the gauge, but no mention of any possible adjustment by rotating the gauge dial.
Now the regulator is nearing 10 years old, so needed replacing anyway and is now well past re-usingf, so just left wondering if the undocument adjustment applied seems reasonable, there was certainly no great resistance in rotating the dial and nothing seemed to break.
The replacement regulator has no gauge and we would like to re-instate a gauge, Gaslow do a gauge that can be added inline with regulator, we would just like the gauge as a backup to help defend against future issues with the gas installation.
Thank you in advance.
