Gas
Coach built
Since 1984
Truma boiler showing gas fault . Gas is full job and fridge working but no heat or hot water
Perhaps there is insufficient flow for the truma. Fridge consumes very little gas.
Does hob work with all rings burning?
We have fridge freezer so takes a lot of gas all hob is working
Maybe a bit more info?
Is the heater gas manifold tap open?
Can you try it with a full gas bottle.?
What code is it showing?
Does it work on EHU 230v?
Have you tried a reset of the unit. Various threads on here as to how to do it.
What is the error code showing on the Truma panel?
Full bottle Error code 512 which is gas. Will try electric when we get to site
I had this a couple of weeks ago. I forgot to turn on the gas but had to go onto the error symbol and press the control button to reset the system.
Have you recently changed the bottle or had the gas valve turned off ?
Sometimes on mine it can take a while for any air to bleed out and gas to get to the boiler, we had similar on a previous van.
After a few attempts to light with a small gap between it always lit.. Fridge can sometimes do the same thing.
Also it can lock up for an hour to stop you ruining the starter.
Sounds like the very standard Truma gas regulator failure.
Would that not cause hob and fridge not to work as well? Curious for future reference.
No. They both need much less gas than the boiler, and also will just run on any amount of gas unlike the boiler.
