- Nov 22, 2018
- 1,803
- 15,196
- Rimor Europeo 87
- Five years plus three tugging
Hi, I have a single bottle Gaslow R67 11kg system with an external filler point. The motorhome gas inlet valve regulator has two outlets with the second inlet being supplied W20 pigtail that could connect to 27mm clip on valve for the expensive B and Q patio gas bottles. The idea was to have two gas options as the number of LPG pumps dries up in Britain.
I have a full 6kg calor bottle with standard POL bayonet fitting. I also have a POL W20 pigtail.
Very simply, can I swap the the 27mm clip-on W20 pigtail for the POL W20 pigtail and use standard calor gas bottles? As far as I can remember, the POL W20 pigtail has never been used and is about two years old.
Also, another gas-idiot question. If both bottles are connected and the taps are both open, does the pressure equalise and level the amount of gas in each bottle, i.e. they end up with the same amount of gas in each bottle? Not that I would do it, I actually would want to avoid doing it.
