- Jun 17, 2021
- 31
- 17
- Swift Bolero
Depends how you tour- if you are off grid then I would fit underslung refillable and "win" the locker spaceJust looking at changing the gas set up in our new MH. Currently have 2 x 4.5kg butane and I have a total width of 54cm.
What is the largest refillable bottle available and should I go for 2 x7kg or one larger bottle?
The so-called contents gauge is simply a pressure gauge. Not much happens until the vapour pressure drops at which point the bottle is close to empty. They're useful but only so you know you're almost out of gas. Better (more expensive) after market gauges are available.Some types of refillable have a contents gauge, either built-in or an optional extra. Without a gauge, there's a case for having two bottles; with a gauge, much less need.
That's the old type I have had gauges in my bottles since 2008 they have always been a float gauge which is accurate.The so-called contents gauge is simply a pressure gauge. Not much happens until the vapour pressure drops at which point the bottle is close to empty. They're useful but only so you know you're almost out of gas. Better (more expensive) after market gauges are available.
That is misinformation no problem with underslung tanks on the tunnel.Worth knowing that Eurotunnel will not accept underslung tanks so you are forced onto the ferries. They will take two refillables in a proper locker that they can (and do) check are physically off at the cylinder.
I was so convinced about it as I remember being told it by a member of their staff years ago so checked, and it seems you are correct.That is misinformation no problem with underslung tanks on the tunnel.
Apologies for the misinformation. I stand corrected.
- For fixed containers (tanks): Maximum of 47kg per container and no more than 50kg per Vehicle if more than 1 container.
They do work, you just have to know their limitations, once they get into the red start thinking about topping up, you will usually still have a couple of days or so gas left even then unless you have the heating on all night!Some types of refillable have a contents gauge, either built-in or an optional extra. Without a gauge, there's a case for having two bottles; with a gauge, much less need.
As above, they do accept them so long as they are for domestic use only and not propulsion which applies even if you have a duel-fuel vehicle.Worth knowing that Eurotunnel will not accept underslung tanks so you are forced onto the ferries. They will take two refillables in a proper locker that they can (and do) check are physically off at the cylinder.
That’s completely wrong No problem at all with underslung LPG tanks in the tunnel .Worth knowing that Eurotunnel will not accept underslung tanks so you are forced onto the ferries. They will take two refillables in a proper locker that they can (and do) check are physically off at the cylinder.
