Fuse box (1 Viewer)
Jul 20, 2018
420
1,177
Bridport Dorset
Swift Kontiki 655
Trailer tent for 10 years Motorhome since 2018
Hi all, just returned home and discovered the passenger side cab fuse box has a fault and has burnt out two terminals. The terminals / fuses supply ignition lights and exterior headlights, indicators, rear lights etc. I’m looking to get a replacement fuse box rather than supplying the damaged circuits separately. It’s a Fiat Ducato 2006 2.8 TDI . Any ideas other than online breakers where I might locate replacement fuse box?
Lenny HB
50,273
138,866
On the coast in West Sussex
Hymer B678 DL
You need to find what caused the problem before fitting a new one.
Secondhand one here.
Dave Scadding
Jul 20, 2018
420
1,177
Bridport Dorset
Swift Kontiki 655
Thanks Lenny HB , looks similar to mine, could do with a bit more cable left on it though, to do connections. I think there’s a fault with the lighting circuit also the connections are weak / damaged in the back of the fuse box on those terminals which has probably caused some arcing.
65
108
Bridport, Dorset, UK
Hymer B664 CL
30 years
martin west dorset thanks I’ll give them a try tomorrow.
I have used them for parts in the past & had good service, but never found Fiat parts to be cheap tho, but like Lenny HB said you need to resolve the high current draw first to avoid damaging a new fuse box.
