Fuse box for Truma on a starlet 2
Bexley Kent
Given up Motorhoming
May 2019
Hi peeps It seems like I have blown a fuse on my heating and HW can’t find a reset button or fuse box the one for the engine heater is ok
Still not found the fuse box. But I have got the heating working just fiddled with everything and it started to work. Now taken my coat off. ⚡️?
Your heating controls are the same as mine, the bottom one is your power selection (you're just using gas). The top one is your heating selection (you are not heating your water and your heating is on max 5). If you are on hook up, the squiggly vertical lines are 240 v, one for 5 amps and 2 for 10 amps iirc. The flame and squiggly lines are for using gas and 240v, for fast heating. The top dial is heating selection, the 60 and 40 degrees is water heating only. For hot water and heating turn the outside dial all the way clockwise (flame and 60 degrees), the inside dial is your heating temperature, if it's like mine you won't want it on 5 for very long.
Hope this helps and I'm not trying to teach you to suck eggs. :D
