Front Springs (1 Viewer)
Musicboy
191
182
United Kingdom
Rapido 7096+
fulltiming since 2003
Has anyone changed front springs on Ducato 3 litre .... I want to raise the nose up on the van & have been advised the change to heavy duty / raiser springs will do , plus a better drive ride if changed ...
From my enq thus far , Conrad Anderson are the nearest to me at the momment .
Any reply would be grateful . Thanks ....
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Yes I've done quite a few now. Goldschmidt are the ones we use and there are two options: heavy duty and super heavy duty. We would need details of your motorhome to establish which would be the best option for you. Bear in mind if it's more than two years old we recommend replacing the struts as well.
D.
Musicboy
Musicboy
191
182
United Kingdom
Rapido 7096+
Thanks Dave . Will call you tomorrow / Monday . Cheers
Nov 5, 2013
3,103
97,825
Shropshire
Carthago chic e-line
Since 2013
Dave did ours,great improvement (y)
Aug 19, 2014
1,855
5,564
Cliftonville
A Class Burstner
Since 2014
I had an E&P levelling fitted at SAP Doncaster and Mick advised me to change the front springs for heavy duty ones.
When we compared my factory fitted ones with another van with heavy duty ones, there was at least 3-4inches more clearance between the tyre and wheel arch. Mick said if I changed to the heavy duty springs and they made no improvement he would refit the originals and refund the cost of the HD springs
I got them changed and they made a huge difference.
According to Mick, he has never had to refit original springs once the owner has changed to heavy duty springs
BreweryDave
3,495
10,542
Alvor, Algarve
None now!
Just let some air out of the rear tyres, have the same effect :LOL::p
Paul and Jeannette
86
51
lincoln, lincolnshire
coach
20 years on and off
should add that we are getting rear air suspension fitted to our suntor 590RL as we will be carrying a scooter on an easy lifter tow bar rack. Any comments on air suspension,for or against.
Oct 7, 2013
5,898
36,938
South Wales
Swift Escape Compact
Since 1988
@Paul and Jeannette
We had air suspension assisters fitted to our last motorhome, a Swift Esprit on a FIAT chassis.
Our drive has a steep slope and the road has a steep camber making a valley where they meet. When new we had less than an inch of clearance as the rear of the motorhome reached the road surface.
We fitted air assist, priced at £230 for the kit on EBay. Took just over an hour to fit.
With the pressure set at 35psi it lifted the rear far enough to clear easily and reduced body roll on corners and round-a-bouts.
No downside that we found.
