Fridge problem....advice needed.
GRUMPY OLD GIT
Pembrokeshire
coachbuilt
Started in1974 with a converted London ambulance
Fridge will not stay alight on gas.
Electrolux/Dometic RM6401.
Lights fine,nice blue flame but as l release the igniter button it goes out and igniter light clicks/flashes.
Have cleaned the flu and burner and fitted new jet. Been away for 2 weeks and all fine (on ehu). Now this !
Suspect thermocouple.
Any advice welcome
Cheers. Bob.
I would go for the thermocouple first. Make sure it has not come loose at the gas valve end as well
First check the earth return from the electrodes at the burner. You could do this by using a separate wire from the electrodes to a good earth point.
I had a similar problem and found the support bracket had corroded where it connected to the earth point. In my case it was probably due to the water container from the fridge overflowing causing the corrosion.
Check the connections on the spark generator box I had to rewire ours.
Also check the connections to the gas valve there are 2, one on each end.
Also check the selector switch gas/12v/240v, contacts had broken down on mine (rm6270) and I bypassed the switch to prove my idea
I even bought a new gas valve ££££s but it was not the problem, still got it somewhere i think
Thank you all for your help.
Tried everything l could on a very wet and windy site down here in Cornwall. Still not working. Have planned a 4 day route back home to Pembrokeshire using ehu stops and will strip out and sort then.
Thanks again Bob.
Another thing to check is the mounting of the ignitor because on ours, the ceramic sleeve came free of the metal bracket it goes through and could turn out of position.
Yes most likely, from your description and previous maintenance that you have done, it's a dodgy selector switch or temperature switch.
Themocouples rarely fail and if it lights ok and good blue flame then the fault is not with the burner/jet/assembly.
I have the same problem at the moment, gas lights ..lovely flame ok, but will not stay on.
Operating the temp gauge up and down a few times and turning the power selector switch on and off a few times relights the gas.
I would like to bypass the switches to give a electric feed to see which switch is dodgy but I don't understand the fridge electrickery.
At the moment at Lincoln Show, it's a really miserable event weather wise, so I am nipping outside to check the fridge burner is lit and having to relight every 2hrs or so.
Update on fridge problems.
Fitted a new thermocouple and touch wood seems to be working fine. Bit of a faff moving fridge forward to get to top coupling but done now. Stayed alight 20 odd times when tested.
Now have to put it all back together.
Once again thanks for your help and advice
Bob😀
Just some info in case anyone searches for the same problem and comes to this thread.
We discovered that our Dometic fridge with the AES will not switch from battery to gas until it has first been switch to the off position.Something to do with the safety feature to stop it sparking up when you stop in a petrol station.
Also after cleaning everything I found a sharp rap on the solenoid valve seemed to unstick it and allow the gas to flow.
