Fridge not working on mains (2 Viewers)
Duck Truck
1,203
1,226
UP North
Hobby 725
Hi all
We had a problem last August with our Dometic RM7651L fridge freezer not working on gas .
Resolved this by removing the fridge and turning it upside down
This is the link to that problem
https://www.motorhomefun.co.uk/forum/threads/help-fridge-not-working.155956/page-2
After doing that the fridge worked fine.
On all three power sources
However the fridge now isn't working on mains electric
Works fine on gas
and fine on 12v
The power selector switch led glows green when switched to mains.
Any ideas as to the problem
Many thanks guys
Kev
bigtwin
5,246
9,953
Derby
Concorde
Yep, sounds like the mains element has gone.
Check to see if there is 240v at the terminal block connection.
If there is, and after isolating the mains, disconnect the element and check its resistance - should be about 250 ohms.
Ian
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
I agree with the above, had it happen to me. Ours tripped the electrics when it went, first day of three weeks in France!
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
As above easy to check, depending on access getting the failed element out can be a test but if you have already had the fridge out once doing it again will be easy if that is easier.
bigtwin
5,246
9,953
Derby
Concorde
I replaced the element in ours through the external vent spaces. No need to take the fridge out if you have top and bottom vents.
The tricky part was getting the metal sheathing that covers the insulation clipped back on.
Ian
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Ian
Exactly my point, it was possible in my case but borderline, with experience of removal you can slide it forward and provide easier access to the shroud etc
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Hi all
hanks to everyone
are the heating elements easy to get
any ideas on a good supplier
who will have them in stock
and the likely cost
cheers
Kev
bigtwin
5,246
9,953
Derby
Concorde
and the likely cost
cheers
Kev
Loads on e-bay, for example:
Look at this on eBay
CARAVAN / MOTORHOME - Dometic Fridge Element 240V /105W RM4 Series – 241323000/0
Ian
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Hi guys
How fiddly a job is it
cheers
jonandshell
5,476
8,299
Not got one!
Mayne the 240v bits are still the wrong way up after being tipped upside down.
Will it run off an inverter?:D
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Hi guys
cheers
No just as @bigtwin said it is the sheath or cowl removal and reinstatement. The element slides into a tube attached to the flue which is surrounded by rockwool which is held in place by the sheath which clips together, so to release it you have to sort of scrunch it together with your hands and as it goes a way up the back of the fridge there can be a shortage of space to get your arms in. Hence if you relieve the fridge fixings and slide it forward a bit it gives you more space to work, but try without first. The odd plug on the end of the cable can be a bit of a pain to pull off but it does come off.
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Groannnnnnnnnnnnnnnnnnnnn
Go on
make fun of my predicament :LOL:
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Thank Michael
for a sensible answer
and not continuing jon and shells doubtful deviation
Kev
jonandshell
5,476
8,299
Not got one!
Don't worry, prior to selling the motorhome, I have a 12v element to change on our Thetford N150 fridge/freezer tomorrow.
I feel your pain!
Oct 29, 2008
5,073
5,975
West Yorkshire
Have you tested that mains is getting to the element with a meter.
Test at the back of the elememt side of the plug as these plugs can also cause loss of mains, its not always the element.
Our last van we cut the plug off and fitted a choc block connector and solved the problem, the plug was sparking.
bigtwin
5,246
9,953
Derby
Concorde
Keep up! Post number three in the thread:
Ian
:D
bigtwin
5,246
9,953
Derby
Concorde
It didn't mention to test after the connector plug which is the weakest point. Not the terminal block connection.
My element is connected directly to the terminal block and there is no plug between that and the element. As per the e-bay example I posted earlier.
Ian
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Hi all
Two things the pic is great
EXCEPT
I don't know what I am looking at
or for
Secondly
The switch for mains is on a rotary switch which goes 240v then gas then 12v
I took the front off and the wiring vanishes behind a large
plastic box on top of the fridge without removing the fridge i can't see behind it for the 240v connections
I soooo wish I had taken pics when i removed it the last time
it was a bit fo a fandangle
bigtwin
5,246
9,953
Derby
Concorde
@Duck Truck
If you’re not sure what you’re looking for perhaps you should consider getting someone else to resolve this for you.
The connections that we have all been referring to are at the back of the fridge. They will be visible behind the lower external vents.
Ian
Duck Truck
Duck Truck
1,203
1,226
UP North
Hobby 725
Hi Ian
I am pretty good at fixing stuff
I simply meant
from the pic it was difficult to see which part was being referred to
cheers mate
