Fridge not sparking up
FOLKESTONE KENT
Burstner A576
I'm a newbie
Does the dometic 7655l fridge have a battery to spark up the ignition.
Tia Martin
As far as I can remember, runs off 12 volt....
Check there is not a bit of rust across the electrode.. (Where the spark should be.)
According to the manual (which presumably you don't have or you wouldn't be asking) the igniter is powered by 12v DC from the leisure battery via the burner control device.
you need to remove the bottom vent and the windsheild so you can see whats actually happening sparking lightning lighting then going out ?
Give all the connectors a push on the grey box where the wires come from to the sparker.
I had to replace the multi way connectors on ours a few years back
