Flexible gas hose (low pressure) perished.
ambulancekidd
Ayrshire Scotland
Swift Kon-Tiki 640
Since 1964 Gosh that makes me feel old.
I was checking over our elderly but well-maintained motorhome today & I knew that the gas hose has very slight marks on it at the start of winter.
Our motorhome has the old-fashioned low-pressure system with quick release to allow me to change from Butane to Propane reasonably quickly.
Today I checked the flexi hoses & got a nasty shock, the older darker coloured gas hose is dated 2019, but perished beyond belief.
The spare connection hoses are stored in the dark & I thought they'd be fine, but wow was I wrong.
The lighter coloured hose is dated December 2020, but it is flawless condition.
So, my next task will be to replace the lot & keep a closer eye on them in future.
Please check your hoses carefully, they might just be in worse order than you think!
Is it the right kind of hose material? If you buy for example a Rothenburger manometer pressure gauge, you have a choice of two hoses: rubber and neoprene. The rubber one says not to be used with LPG. The neoprene one says LPG only. I don't know why, but maybe this rapid perishing is the reason.
When was your last habitation check? Should have been picked up then shouldn't it?
It was as mine with a note that the regulator would need changing the following year.
Is 2019 the date for replacement or the date of manucacture?
Manufacture, it feels a lot less flexible than the slightly newer hose.
I look after it myself, I checked the gas hoses in December & there was a slight sign that they were due some attention. So I keep checking the van regularly, that's when I came across this shocker.
manufacture date,and you only need to change them when perished.
Expiry date in spain & house insurance becomes void if they are out of date & there is a claim because of gas. 5years is the limit of the date system
Any recommendations for decent quality rubber hose if these Amazon ones aren‘t much cop?
could do with replacing mine.
As I suspected, a pile of do do.
The main page on Amazon shows a 4.5 out of 5 stars for it.
Reading the reviews makes you wonder how they can justify that. A number of 1 star reviews declaring the hose “dangerous” and “accident waiting to happen”.
