Flat battery. Can’t lock the Moho door. (1 Viewer)
Apr 1, 2020
144
160
Zefiro 696
I’m a newbie
Hi all
i received a telephone call from the tracking company about an incident with the Moho. it’s In storage so went up to investigate. The battery is completely flat, the growler alarm isn’t working and I couldn’t lock the passenger door. Why would this happen. We last used it at the end of September but we have a 120 W solar panel.
it’s a fiat Ducati registered 2019. Is this normal
kind regards Karen.
17,640
43,429
at the shortest day in the northern hemisphere, your solar panel can't keep up with the constant discharge from the alarm, immobiliser and other current sucking devices
9,074
18,614
Salisbury
Hymer B678DL A class
Probably not enough input from solar to keep battery topped up as not a lot of winter sunshine lately?
797
1,392
south yorkshire
since 2004. Tugger 10 years on and off
Shouldn't you be able to lock the door with the keys.?.
andy63
4,672
15,018
south shields
since 1990
Hi all
kind regards Karen.
Hi.. you should be able to manually lock the passenger door then the drivers door with the key..
Do you have a non start as well as the growler?
Andy
Ps..are you also sure you have the facility to charge the start battery from the solar..
Belledog
Apr 1, 2020
144
160
Zefiro 696
I’m a newbie
Andy
No I have got that wrong . The solar only charges the leisure battery. I have a ghost immobiliser and smartrack tracker. Do I have to turn the alarm off to keep the battery stable.
andy63
4,672
15,018
south shields
since 1990
I would say you would be far better making some provision to try and cope with the start battery drain.. something along the lines of a battery master type device or a dual output solar regulator..
A bit more solar would help as well..
You have a fewitems which will all most likely be wired to the start battery.. the alarm.. you mentioned an immobiliser and a tracker.. ..
Re the passenger door..did you see my initial comment..
Lock it manually then drivers door with the key..
Andy
Dave116610
10
Twickenham
Swift lifestyle
I am a newbie
As for locking the passenger door I am shore a video on YouTube shows moving a lever located in the edge of the open door under the catch. Once this is moved just shut the door, its locked.
Hope this helps.
Belledog
Apr 1, 2020
144
160
Zefiro 696
I’m a newbie
