Motorhomer14
Below Vlog on fitting and using a Gaslow gauge on my propane bottle. Makes checking for gas leaks very easy when you arrive on site.
If you watched the Vlog I did state they are no good for level checking. This is purely for leak testing which they are very good fordont bother they are wildly inaccurate
As i said only using for gas leak testI assume it is just a pressure guage. If it is it will always show the same pressure until nearly empty. Always have something on that you know is using gas, ie hob, then check reading. It will also change with temperature, high on a hot day, low on a cols day.
As mitzimad@ says, dont bother.'
I have one which is an integral/standard fitting in my Gaslow/Calor system and it does exactly that.As i said only using for gas leak test
no worries i understand these are not so good at level checksYes you are right in that it can h4elp confirm a leak in the system after the bottle. I admit I did not read the Vlog, sorry for my irrelevant post.
Hardly surprising they say this....Our gauges are extremely accurate so please rely on them.'
extremely accurate on the last 2 per cent of the bottleInteresting comments about Gaslow guages. I emailed them about slow filling of my bottle and this was their response.
'Please note that cooking for 2 weeks will use very little cylinder contents. Please use your cylinder contents down until the gauge goes into the Yellow. Our gauges are extremely accurate so please rely on them.'
Kind regards
Not bragging but ours does this automatically and it flags up on the Truma control which bottle you are using - very useful.I don’t check them very often as I work on using one bottle til empty then switch to second but my Gaslow bottle gauges seem reasonably correct
I didn’t want the auto change over, I just wanted to know when I had used one bottle so I can start looking out to refill. I know a lot of folk prefer the auto changeover though.Not bragging but ours does this automatically and it flags up on the Truma control which bottle you are using - very useful.
