So it was our first weekend out. (Rollerteam Autoroller 400 2010). Wanted to stay localish just in case and the sun was set to appear. All good
Bought this van in January from an established dealer, gave him a fantastic van in exchange it was just the layout wasn’t for us long term but this weekend was a nightmare and it didn’t help because I left the suitcases at home and they had to be emergency dropped off
Last week I had it looked at as only two lights working out of 9…some fears there’s a PCB issue and the technician managed to sort as a temporary fix but thinks we needed a board after the summer was over and van out of regular use.
Hooked up on arrival and then it went downhill.
If anyone can top this weekend or find me a PCB I’ll buy you a pint
On the plus side, what a wonderful site Gaerhyfryd in Corwen is Highly recommended. Beautiful location, very quiet and lots of lovely walks.
1)the toilet does not flush at all. No power to the flush button
2)no heating or hot water. The Truma controls light up temporarily if you wiggle the fuses. After 20 minutes the power to the control goes. The combi is warm so power obviously getting to that.
3)water pump is running continuously again when you turn it on. I cannot run it to see if it’s pressure or air lock related because the truma combi dumps the water again all inside the van. The dump valve remains in the closed position when this is happening, therefore there is no water either as I can’t have the pump on. Should the water even go into the van because if as they instructions say it dumps at 3 degrees, there is going to be water dumping when we aren’t there to look at it and it floods the whole van. Should there be a pipe leading outside even from the dump valve and currently there isn’t, hence it just flooding the van?
5) the van is on hook up and the noise from the batteries under the seats is quite loud. Constant whirring like a fan. This does cut off for about twenty minutes then kicks in again for a few hours.
