Thank you that’s the one I think I may have been looking for under engine covers don’t know why I could not find it.there are a couple on fleabay at around £60 with fittings.
Fiat Ducato Citroen Relay Jumper Peugeot Boxer Under Engine Cover 1994-2006 | eBay
Fiat Ducato| 1994 - 2006 |. Citroen Jumper| 1994 - 2006 |. Citroen Relay| 1994 - 2006 |. Peugeot Boxer| 1994 - 2006 |. Under engine cover+ Fitting Kit. When You buying a cover note the accuracy of the holes, handles.www.ebay.co.uk
fitting
The four front cross member bolts I thought were the same ones as the bumper fits to that’s four front onesThree bolts to the rear on the subframe . Four to the front cross member . I can give you the thread size and length if needed . There are two nuts fitted , each side in the wheelarch's , but frankly , these may not be useable . Mine seared off , so i don't use them .
The part you've ordered is an aftermarket part , it does fit , i have one on mine . However , it does rub against the sump , so when i refit it (i'm working on my van right now) , i'm gonna fit some spacers . I can supply the information for them , again if you need it . All extra parts sourced from ebay .
They are not listed on any ebay motorhome lists , but on Ducato spare parts list , so that maybe the reason , why you struggled to find them . Also advertisers are a little short at this time of year , should pick up in the New Year . Also take a look at Coastal Motorhomes on google for a vehicle of this age .
Ah yeah , your quite correct , i missed that . Back ones are the same thread and length as the front , the holes do need some finding though . I've only just found your reply , and it's a bit dark outside now . So tomorrow i'll get my David Bailey hat on , and photograph them . Should find them easy enough then . I didn't need any ramps for the cross member (eh , yeah been there too , sorry) , though i did use a jack to support it while i engaged the bolts . I torqued them up to 30 nm , before you ask . I couldn't find the correct setting anywhere , so i went for the middle figure of a standard setting for those size bolt's .The four front cross member bolts I thought were the same ones as the bumper fits to that’s four front ones
the back bolts I do not have yet so details on the back ones would welcome.
I have not fitted it yet as it arrives this week. But I still have the cross member to change as it is rotted but covered up with GRP.
that cross frame I have but now need some ramps to get under it to do that as well.
the one I have ordered is this one. But a bit cheaper from another seller hence no bolts.
Well that is good news , i think that's pretty much what i paid for mine , but it was a while ago .The tray has arrived. A total plus vat and postage £48.00
pleased with that amount.
The main problem seems to be the quality and thickness of some of the underside steel componentsInformative post thanks.
Now I have to decide if I need one of these ???
Yeah we got that problem here too .weather stops raining or drizzling
Exactly my sentiments .The good news with all these little jobs is that when there done you know there done right.
Oh god , so how the hell did you manage that ? . I'm sure it is awkward , i've been there , when i had a similar incident 40 odd years ago . I broke both legs in a motorcycle accident , and put myself in hospital for 4 weeks . Wasn't too bad in hospital , as the nurses were always up for a laugh , but when i got home , i became bored rather quickly . To relieve that , i decided to repair my motorbike , very difficult when your still walking on crutches , but i managed . Not that there was much wrong anyway , new indicator , straighten the foot pegs , new battery . However , once done , i tried to move it , only to discover the front brake had seized . Dealing with that , i decided i had better test it . So i got my helmet , propped my crutches against the shed , and pushed the bike out of the garden . Kick starting was difficult , but again i managed it , and off i rode . About 2 miles worth of around the block . Not what you would call a comfortable ride , with one leg in plaster , not a usual cast , this one had a hinge . The other was stiff , after having had a pin driven in , i couldn't get my feet on the foot pegs properly , but the can do attitude kicked in again and i managed . Never occurred to me , that if something happened , i wouldn't be able to get back . I couldn't walk without my crutches , and of course there was no such thing as mobile phones .I have a broken thumb first metacarpal.
Hmmm , maybe you should lay off the Ian Botham impersonation then , mate . I repaired much quicker when i was younger , but i'm not quite so quick now .all sorts of different parts for the same make and the same year .
Be careful with that one . I used to spray the brake lines on my old van with WD40 to prevent corrosion . On one occasion it got picked up during an mot , as a potential leak . I explained what it was , and got away with it because the examiner knew me . I now use a different pipe , which is mixed with nickel , and so less likely to corrode . The result is i don't use this practice any more . Brake pipes on my car are 9 years old , yet the pipe looks new . The down side is it cost twice as much .Before the underside engine cover goes on it will be getting a good coat of waxoil.
Normally i would agree with that statement , however in this circumstance , i can't . Even allowing for the fact , a vehicle will deteriorate , just stood still (and my van is twenty years old) , what i've found , i would expect on a high mileage vehicle . My vehicle has not even covered 50.000 miles yet . So in this circumstance , i would conclude this as accelerated deterioration .corroded including the power steering pipes
