Fiat Ducato Diesel Particulate Sensor Woes
Shropshire, UK
Adria Twin Supreme
Returner after 20 years without a Motorhome
Has anybody experienced failure with the diesel particulate sensor on a recent Fiat Ducato motorvan or Motorhome?
We ordered a new Adria Twin Supreme SLB in October 2020 and finally took delivery in September 2021. The vehicle is great but we have had problems with the starter battery which seems to charge from the EHU but not from the alternator. I thought the battery was at fault and had it tested by a Fiat Professional garage who told me the battery was fine but they didn’t check the alternator.
Finally, last week I took it to another Fiat Professional garage for a diagnostic check and they told me that both the alternator and particular sensor are faulty and probably have been for some time. They are prepared to change both items under warranty but tell me that the sensor is on back order and may not be back in stock for some time. Furthermore they say I should not drive the vehicle le until the sensor is replaced
So does anybody know if these sensors are readily available anywhere in the U.K. and also if it is best not to use the motorvan until the sensor is replaced?
Thanks for looking
Bob
If you mean dpf pressure sensor then there are 2 different ones fitted to a ducato , is it a 6D or pre ad blue.
There are shortages of particular parts from time to time that may be in some parts store not in general circulation.
Thanks for your reply. I’m not sure which type of sensor is at fault. The garage said they would get back to me on Wednesday to see if the part is available. If they still can’t get one I will ask them which sensor it is and then search around for one. It’s a real pain now the spring weather is here and we want to be off in the van
Plenty of hits if you search
Thats not great!
Surprised the dash wasn't lit up like a christmas tree
