- Sep 25, 2009
- 814
- 1,469
- coachbuilt
- since 2004. Tugger 10 years on and off
We have EBikes and have seen on web EBike replacement rails. I know about the Weight difference, But wondering if anyone has changed theirs.
Cheers Kelv. Will look into them.Ive seen John cross do them.Changed mine from the standard rail supplied with fiamma rack to ebike rails they are about 100mm longer to allow for the extra length on a ebike.
Easy job just a couple of bolts to undo and tighten.
I have 2 kalkhof ebikes one did fit on the rail but the other one was border line so I decided to change the rails so yes I agree it is worth measuring your wheel centres.We never changed our standard rails when we got our Ebikes, (Kalkhof Aguttu's which are longer than standard push bikes) The Ebikes still fit on with a couple of inches spare either end of the rails. Have you measured your wheel centres to see if you need to change ?
Same bikes: we never changed the rails the seemed to work okay but ours were the 46in wheels - if you have the largest would consider upgrading the rail but again otherwise fine.We never changed our standard rails when we got our Ebikes, (Kalkhof Aguttu's which are longer than standard push bikes) The Ebikes still fit on with a couple of inches spare either end of the rails. Have you measured your wheel centres to see if you need to change ?
Blimey you must have long legs.but ours were the 46in wheels
