extra leisure battery (1 Viewer)
tojo
14
8
hymer b584
Hello all
I am looking to put an additional leisure battery in my Hymer B584 , the leisure battery that is in is under the passenger seat i am thinkink that i would be ok in siting the extra battery under the drivers seat [ he motorhome is LHD ] would i need to put a inline fuse , be grateful for any advice .
Steve .
Sep 25, 2012
522
1,228
West Cornwall
13 Years, 20 years with a caravan
I would first check out the age of your current battery as it would have an impact on any addition. Also what type :- Gel/AGM or Wet Flooded.
Other Hymer owners should be able to help with the physical fitting for you.
Phil.
Aug 15, 2014
2,580
3,462
Exiled in Yorkshire
Pilote 600L
I have two leisure batteries fitted in the outside locker, passenger side on my 06 reg B584.
T
tojo
14
8
hymer b584
Thanks for that , the battery looks reativley new , also found this when looking at the battery , anyone any ideas ?
53,476
150,202
Batties are fairly close so no need for a fuse, Hymer don't fit one when they do it
T
tojo
14
8
hymer b584
hi all
am in the process of fitting an extra leisure battery to my hymer , i will have 2 x 90ah fitted , would i be ok connecting them both using new cable from a set of 3m starter cables ?
steve
Aug 5, 2018
1,567
3,513
a
Depends what size the starter cables are.
If you mean "jump leads" then you can get cheap chinese ones that I wouldn't trust to jump a scooter and then pro jobbies designed to start trucks. It's no good looking at the size of red and black plastic, you need to pull the gland back (ooh err) on the crock clip and look at the size of the copper core.
SuperMike
2,477
7,593
St Albans
Winnebago Sightseer
On quality cable, :gum: the size “should” be stamped on the outer insulation. Please note the words quality and should. :emo:
Apr 27, 2016
6,874
7,996
Manchester
A class Hymer
Since the 80s
That is an 80Ah Gel battery. It's best to fit one that's exactly the same type (Gel), and about the same capacity (80 Ah at the 20 hr rate). Use wire that is just as thick, or slightly thicker than, the existing battery wires. If the starter cables are like this then using them to connect the batteries will be fine, if you fix proper battery connections onto them.
If it was mine I would fit a big fuse at each end of the positive interconnecting cable, but some people might think that's a bit OTT.
T
tojo
14
8
hymer b584
Hi All
Not going to risk the starter/jump leads , will wait till i get to the motorfactors and get the proper stuff .
11,955
16,570
Trace the wiring from the plug / socket before you do anything. It just might be a connection across to the passenger seat for another battery - unlikely I know but I'm struggling to think what vehicle-related sttuff it might be for. The only thing that springs to mind is heated seats.
53,476
150,202
hi all
steve
If using jump cables you the heavy duty ones where the conductor is many strands of fine copper. Cheap ones are often aluminium and will be useless. Probably better & cheaper to buy the right cable.
Apr 26, 2015
2,772
6,894
Ottershaw
Hymer S820
First motorhome May 2021
You might find the following site useful as it rates cable by the amperage it is capable of carrying as well as the size.
