Extension kit for grey waste (1 Viewer)
May 4, 2015
1,240
1,632
North Yorkshire
since 2000
This is the outlet pipe for our grey waste it’s approx 60mm internal, it extends to 1m. 1m is not enough length, I can’t find anything logical to extend it, nor an adapter large enough. It’s not been a problem in the past as we have been on aires that usually have a drive over drain. We have been on a few CLs and find we cannot get near the waste drains.
Any thoughts please.
Greame.M
40
48
Peugeot Swift 590
Being a total newbie, we went out for the first time to a services pitch and used a bucket to empty the waste😕 we have some sort of brass valve with about an inch male connector needed for a hose🤔
Mar 14, 2019
1,124
1,123
Sutton Coldfield but East Yorkshire man at heart
Elddis Autoquest155
Since 2018
I went to my local caravan accessories shop and purchased a length of the grey pipe. I also have a couple of waste pipe elbows (45 & 90 degrees) to use at the drain end to stop the bulge/back flow caused by just poking the pipe down the hole.
Our waste pipe supplied is a flexible 40mm hose, the original is 2metres long but I could do with 5 metres due to time when I needed it.
Bailey58
8,815
29,551
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Like others I use convoluted hose saved from the last garden pond upgrade. A couple of 5m lengths with one end adapted to slide onto the van outlet and a joint connector if I need to use both. Rolls up neatly into a plastic sack after a rinse out.
Jun 6, 2020
265
207
Apache Hi Line 634
I bought adapter and two packs of pipes (Brighton MHC site has the longest run to the services). Had piping cut before and wasn't the best when storing - the two packs of Colapz fit into one bag
