Good morning. We have an error code E634 on our control panel and can’t seem to find reference to it on the Truma Code list. Can anyone help please. It’s obviously a heating problem cos we’re freezing . Many thanks
We turn heating off at night and we got this code this morning when trying to put it back onWas the heating working last night?
Depends what system you have. Our Refillable gas low ones have gauges. Calor gas bottles will be light when you pick them up.We think so but how can you tell ?
Yes. Sorry but appear to be really dim. Just thought to switch gas job and yes still have gasDepends what system you have. Our Refillable gas low ones have gauges. Calor gas bottles will be light when you pick them up.
Alternatively try lighting the hob.
Then I can be of no further help, sorry! Good luck in sorting it out.Yes. Sorry but appear to be really dim. Just thought to switch gas job and yes still have gas
Ahh ok. Thanks for trying anywayThen I can be of no further help, sorry! Good luck in sorting it out.
I know. We did see that and there was a light frost last nightThe codes only seem to go up to 624 and that means "Frost control heating element short circuit"
does help much but on the Truma web site E634 is an unknown reference. As others have suggested try to clarify if it's related to electric or gas.Good morning. We have an error code E634 on our control panel and can’t seem to find reference to it on the Truma Code list. Can anyone help please. It’s obviously a heating problem cos we’re freezing . Many thanks
The code is listed in this document, i cannot make the very bottom of the pdf show on my ipad but I suspect the action will be the same as for the codes above.Good morning. We have an error code E634 on our control panel and can’t seem to find reference to it on the Truma Code list. Can anyone help please. It’s obviously a heating problem cos we’re freezing . Many thanks
Just our luck . I’ll give our servicing agent a call as soon as we candoes help much but on the Truma web site E634 is an unknown reference. As others have suggested try to clarify if it's related to electric or gas.
thanks so much. Will check it outThe code is listed in this document, i cannot make the very bottom of the pdf show on my ipad but I suspect the action will be the same as for the codes above.
I’m not sure it helps you much View attachment 486755
that’s really helpful. Thank youThe code is listed in this document, i cannot make the very bottom of the pdf show on my ipad but I suspect the action will be the same as for the codes above.
Many thanks. Have carries out all these tasks but to no avail sadly. We’re going to try ans contact a mobile service when we get to our next pitch in Tintagel. Usually the club will have contact detailsIn this thread, there is a photo of the reset button on the boiler and read to the end where it says wait 15mins
Truma combi no heating ?
Sorry to hear that....only other thing is the small white fuse on top of heater? Might be something like the water temp sensor needing replacing......www.motorhomefun.co.uk
Good luck.Many thanks. Have carries out all these tasks but to no avail sadly. We’re going to try ans contact a mobile service when we get to our next pitch in Tintagel. Usually the club will have contact details
