Often they fail on emissions due to people gently tip toeing around in their mobile love nest, not driving it like a delivery van.It was registered Dec 2017 2.3 multijet 130
Automatic it's done 16000 miles failed first mot
on emissions in December
If you donāt drive like an old fart, doing fuel consumption flow charts, you will be fine. Mine felt like it was restricted until I got a few miles of hard driving done in it.That may be so but I've spent the last 20 years driving delivery vans
Have You had it from new. have you driven its 16000 miles?That may be so but I've spent the last 20 years driving delivery vans
Then tell them they should be paying for it as even under EU regulations anything is expected to last a minimum of 6 years & for stuff like that to be requiring replacement isn't on.It went again was replaced under parts warranty then went again now Fiat say it needs
New injectors low pressure egr valve 2 heat exchangers plus extras
Sounds like they either don't know what's wrong. Or some issue is causing secondary problems... or both.It went again was replaced under parts warranty then went again now Fiat say it needs
