Electrobloc Fuses
Chipping Norton
Carthago-Malibu T460
Since 2015
I have a recent Burstner motorhome with an Electrobloc EBL119 power unit under the passenger seat. For weeks now I have had a problem with the fridge/freezer, awning light, outside door light, tv aerial and inside entrance lights not working.
I had checked quite a few fuses in case anything had blown -including some on the Electrobloc- but everything seemed fine. So I did a bit of reading of the handbook again and it seems that there is a 25A fuse in position 4 (labelled "25A Reserve 4") which seemed to cover all of the units that had failed. So, I went searching and found that there was a 10A fuse fitted in position 4 on the Electrobloc unit which -when my podgy fingers had extracted said fuse- found it to be blown. Thinking that a wrong fuse had been put in at the factory, I replaced it with a 25A fuse and everything works fine.
But was I right, or should I have replaced it with a 10A fuse again or even a 15A/20A fuse as a compromise???
You need to define what exactly is connected to that fuse & the total current requirement.
Try A&N in Wales.
Hi Lenny,
Need someone to check my theory. Fridge is 14A absorption type Dometic. As there seems to be a separate 20A fuse near the vehicle battery to cover this, I assume the fuse I found on the Electrobloc covers only the power requirements of the control panel (which Dometic say in their online fitting instructions should be covered by a 2A fuse). So that power (2A)+Awning led lights (5A)+Entrance led lights (2A)+Aerial amplifier (0.1A) 9.1 Amps. Which could explain why a 10 Amp fuse was fitted as it would unusual for all these to be on together.
Regards Ian
We have a 2019 Hymercar and it has an Schaudt Electroblock EBL 30 and to assist me with understanding the van electrical system I was able to download the instruction manual in English which I think was from the Schaudt website. All the fuse positions are are shown with their appliances and that does seem to be consistent with what has been installed on my van and it has been very useful in understanding the van electrics.
Thanks. I'll check that out.
Hi Lenny,
Regards Ian
The 20 amp ones shown here are the main ones for the fridge, on our Hymer there is a separate fuse block next to the EBL that has the 2 amp fuse for the fridge electronics.
That sounds about right then. I'll replace the blown 10A fuse with another 10A and if it ever blows, at least I will know which one it is. Thanks Lenny.
Hi Lenny,
Regards Ian
The 'Reserve 4' circuit is one of the extra circuits, in addition to the named ones like TV, Heating etc. It has a higher amps capability than most of the others.
The MNL connectors on the front of the EBL have a max current rating of about 15 amps. Two of the circuits, Reserve 3 and Reserve 4, have two pins for positive, and two pins for negative, to permit a max current of 25 amps. It's not obligatory to use this extra current capacity, and there's no reason not to use it just like a 15A circuit. Presumably that's what Hymer decided to do.
Maybe an extra item or two has been wired into this circuit, so the maximum current with everything on is enough to blow the 10A fuse. You could use a 15A fuse, which would allow for the possibility that only one of the two-pin pair was used for this circuit.
Reserve 4 is special in that it remains on when the habitation 12V is switched off at the control panel.
Thanks Autorouter.?
