Electrical tech advice 8 pin plug (1 Viewer)
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
Help please looking 8 pin socket for electric bed actuator and how to connect it.
I am in the process of replacing a Hiwin actuator on my 2011 PILOTE Motorhome.
I had to cut the wire from the control unit to the actuator so need to join the new wire to an 8 pin plug.
The control unit is a Stromwert 6a unit P-SC2MD2-40-1
I cant find any reference to Stromwert controller on the net.
Poor picture of the plug/ connector I'm seeking attached.
Ideas welcome on where to get an 8 pin plug and how to join it to the 8 core wire to it.
Thanks Chris
11,956
16,571
There are many varieties of 8 pin plug available. With no better information you will need list each pin against its controller / bed connection then wire a plug (and maybe a socket) to match.
Jun 8, 2019
4,931
18,760
Bexley Kent
Given up Motorhoming
May 2019
I believe it’s called a din plug. I stand to be corrected. Available from Amateur radio shops
Wonders
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
Thanks I still have the original plug with a good length of wire attached might be better to join the new wire to the original. That sets me another challenge to find a a suitable joining block. Any thoughts.?
Aug 18, 2014
23,808
133,954
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
Solder each wire? Is what I would do.
If not crimps or choc block as last resort.
Jun 8, 2019
4,931
18,760
Bexley Kent
May 2019
Local amateur radio club or model boat builders aircraft builders, will have people who can solder miniature wires probably won’t charge you.
Wonders
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
Vipar
Thanks for your help
I have a mate who is a model boat builder I bet your right he can solder.
Wonders
Aug 17, 2020
207
313
Leicestershire, UK
Pilote
Since 2011
Thanks all speedy and helpful guidance I feel more able to sort this than I did a hour ago.
Just hope my actuator gets repaired
Chris
