Electrical tech advice 8 pin plug
Leicestershire, UK
Pilote
Since 2011
Help please looking 8 pin socket for electric bed actuator and how to connect it.
I am in the process of replacing a Hiwin actuator on my 2011 PILOTE Motorhome.
I had to cut the wire from the control unit to the actuator so need to join the new wire to an 8 pin plug.
The control unit is a Stromwert 6a unit P-SC2MD2-40-1
I cant find any reference to Stromwert controller on the net.
Poor picture of the plug/ connector I'm seeking attached.
Ideas welcome on where to get an 8 pin plug and how to join it to the 8 core wire to it.
Thanks Chris
There are many varieties of 8 pin plug available. With no better information you will need list each pin against its controller / bed connection then wire a plug (and maybe a socket) to match.
I believe it’s called a din plug. I stand to be corrected. Available from Amateur radio shops
Thanks I still have the original plug with a good length of wire attached might be better to join the new wire to the original. That sets me another challenge to find a a suitable joining block. Any thoughts.?
RS catalogue?
Solder each wire? Is what I would do.
If not crimps or choc block as last resort.
Thanks not confident in my soldering ability. Might find someone who is so I can retain the original wire and din plug
Local amateur radio club or model boat builders aircraft builders, will have people who can solder miniature wires probably won’t charge you.
Vipar
Thanks for your help
I have a mate who is a model boat builder I bet your right he can solder.
Thanks all speedy and helpful guidance I feel more able to sort this than I did a hour ago.
Just hope my actuator gets repaired
Chris
