We had a funny smell in the motorhome and on investigating I found one of our Gel habitation batteries cooking.
I have disconnected the negative to the said battery and the cooking has stopped and it appears that all of the 12V electrics are still working and the BMV battery monitor is showing 14.4V (as is the Carthago panel).
My question is if I leave the battery disconnected as per the photographs (I will properly isolate the disconnected cables), will it be okay?
We are currently on hook up (not charging as far as I can tell) and have 320W of solar panel, 2nr 100W panels attached individually to the hab batteries via Victron MPPT controllers, which are both showing ‘float charge’ and an Alden Phenix panel connected via its own controller which is also showing ‘float charge’. We also have a Sterling BTB fitted but this only runs when the engine ignition is on.
Thanks in anticipation.
Richard
Richard
