Hi Bernie thanks for info. I will always be using hook up so no problem there, what I am trying to find out Is what could happen if say fresh water tank heater is on and water level drops through use will it damage the heater if it ends up above water level.So when would you turn it off or can it run continuously.I have spoken to Elddis and will post there response when received.We have a tank heater in the fresh water tank on our V Line, but the tank and inlet pipe is well insulated and we have camped several times in - 3 to 8 deg. The - temperatures have only existed over night though, so I cannot comment on continual minus conditions as one would experience if winter skiing.
Not having EHU on several occasions so only relaying on our 12v system the heater has never come on as we have checked the battery monitor, I can only assume that because of the insulation the water has never dropped to the point that the heater has automatically energised.
BernieT
