Does anyone know if they are recorded digitally? 2017 Fiat Ducato
Don't know - but you can use MultiECUScan to see how many services its had, how many oil changes and last time it was done.I can't find these does anyone know if they are recorded digitally? 2017 Fiat Ducato
Just keep on top of dealers for ECU updates. As I said above, vans not getting the latest ECU update can suffer expensive damage (appears to be the non ad blue euro 6 ones on v30 of software with the issues)I do all my own servicing (so it had never been near a garage) which basically means changing the oil ever two year's or every 16k miles.
I traded my last van in with a dealer at 58k miles and he had no interest what so ever in its service history.
Anyone with MultiECUScan can record services, set Oil changes, modify service intervals etc.Don't know - but you can use MultiECUScan to see how many services its had, how many oil changes and last time it was done.
Problem is some people use cheaper garages or their local trusted who may not update ECU with details.
True.Anyone with MultiECUScan can record services, set Oil changes, modify service intervals etc.
So checking this data does not mean it's been serviced by Fiat.
Red.
I've had the recall on the brake pipes problem.Just keep on top of dealers for ECU updates. As I said above, vans not getting the latest ECU update can suffer expensive damage (appears to be the non ad blue euro 6 ones on v30 of software with the issues)
Looks like I need to dig out my OBD2 reader (Topdon) bought for an airbag fault with the last van standing during covid. When I got the van last year I was shocked by the frequency with which I had to change dow from top on motorways as I never had to do this on my 2014 ducato so maybe the version does need checking too.True.
But check the ECU software versions - v32 is the latest. v30 can be a problem
Have you a source that v30 is a problem or just working on principle that vans with issues are switched to 32 ASAP service bulletin no xxxxx ( can't remember number and away from home) and are earlier versions ok?True.
Only third hand from someone I know doing lots of research on the topic. See https://www.fiatforum.com/threads/d...ro-6-egr-changed-what-do-i-check-next.491167/ for one of the threads he is commenting on.Have you a source that v30 is a problem or just working on principle that vans with issues are switched to 32 ASAP service bulletin no xxxxx ( can't remember number and away from home) and are earlier versions ok?
Airbag fault *tend* to be caused by low voltage and tend to require physical fix of ECU.Looks like I need to dig out my OBD2 reader (Topdon) bought for an airbag fault with the last van standing during covid. When I got the van last year I was shocked by the frequency with which I had to change dow from top on motorways as I never had to do this on my 2014 ducato so maybe the version does need checking too.
Sorry p401 just a shorthand , some have the habit of reducing it to 401.Well, I know people try to help but they're not talking a language that I understand. I've googled software versions 30 and 32 and come up blank. Similarly I've found absoluely nothing about P401 problems, there is a plethora of P0401 though.
See what I mean?Sorry p401 just a shorthand , some have the habit of reducing it to 401.
One big problem for those with this code is that it is believed that Fiat is misusing it for the twin egr system. It typically is used for the egr valve eg the hpegr valve in a twin system but a number of people have found it to be a red herring.
Please explain the problems I have a pre adblue euro 6Just keep on top of dealers for ECU updates. As I said above, vans not getting the latest ECU update can suffer expensive damage (appears to be the non ad blue euro 6 ones on v30 of software with the issues)
See links above on fiat forum and info from the1andonly.Please explain the problems I have a pre adblue euro 6
Sorry to sound so dim but where do you create an account? I've looked through the Fiat websites and can't find any such.Yes they are and if you create an account there is information held there as well.
From my perspective there are a few questions , this relates to the twin egr euro6 motorPlease explain the problems I have a pre adblue euro 6
In my experience very few garages outside of the main dealer network record services on the ECU although it is easy to do so.Anyone with MultiECUScan can record services, set Oil changes, modify service intervals etc.
Red.
Red.
The very top right of the web page you will see "My Fiat professional" click on that I think you need the VIN number to register and you can manage your MoHo from there.Sorry to sound so dim but where do you create an account? I've looked through the Fiat websites and can't find any such.
Thanks. Will try againThe very top right of the web page you will see "My Fiat professional" click on that I think you need the VIN number to register and you can manage your MoHo from there.
Fiat Professional | Commercial Vehicles & More | Fiat Pro UK
Discover the Fiat Professional range of commercial vehicles and vans built for every business need. Explore models, features, and offers today with Fiat Pro UK.www.fiatprofessional.com
