Ducato multi function display woes
Pretoria, South Africa
C class
since 2005
Hi Fellow funsters---I now cant get my 2018 Ducato multi-function display (MFD) to show the full menu to enable me to change the date / time/ units/autoclose etc when the vehicle is stationary with ignition on, previously i could set them ok. It seems as if I can only access the reduced menu options ie speed beep/ service/pass airbag/exit menu functions that you can normally change when the vehicle is moving, The time on the MFD is flashing as if its ready for setting using the up/down buttons but they have no effect. I have tried disconnecting, waiting and reconnecting the battery to reboot the computer but still the same result . The trip computer and messages, eg door open etc show on the display correctly. Please have any of you multi function experienced funsters encountered the same problem and have any suggestions to resolve Thanks Peter
I was on a field with a chap who was having the same sort of issues as that. He was advised to remove the earth from the battery for 10 mins then re attach. All seemed to work OK after that.
I don't have one but on most electronics a reset usually works.
A copy of multiecuscan and cables to do a proxy alignment and then any future diagnosis will be the best £100ish you can spend 👍
Thx for the feedback, I went back and looked through the MHF forums and found a comment from some time back about some multi-function display items being controlled via the radio settings - strange but true!
Hey presto, job done, happiness reigns
