- May 19, 2018
- 293
- 466
Hi all,
I started the van yesterday after a few months of sitting idle. Immediately the engine warning light came on. After a few minutes the tick over rose to 1100 rpm and just stayed there. Then after a few more minutes the battery warning light came on too. The van is on hook up so as soon as I turn it off the battery starts charging again.
I've put a meter on the battery with the engine running and it starts around 12.5v but steadily decreases.
I'm guessing it's the alternator but am facing several problems :
I can't tell the make, model or code of the alternator as its right at the back of the engine and my glasses don't work round corners.
Apparently this problem might be the regulator but to get spares I need the make model and code.
I've looked at prices for a replacement and they range from £100 (with £50 back on returning the old one) right up to over £550!
The earth strap seems fine, both ends are tight and the strap itself is clean and dry.
Any suggestions would be appreciated.
It's a 2007 x250 2.3 130 engine, not sure if it's the slightly over 130hp model or the slightly under 130hp model.
I've seen remanufactured bosch alternators advertised for less than £150. Does that seem a realistic price?
Alan
Alan
