Drain down tap leaking (3 Viewers)
DBop
53
26
Evening folks,
Today I was prepping the Moho for future trips and noticed both drain down taps had water leaking from them whilst running the kitchen taps.Has anyone had similar snags and if so what was your remedy? I have unscrewed the taps and applied some silicone sealant to see if that works! I’m thinking of changing the drain down taps at a cost of £18.50 a piece. Thanks in advance for your replies. I’ll also attach a picture.
DBop
DBop
53
26
looking at the blue cap(unscrewed) in picture #2 they both look very clean with little or no build up of any kind. Would I be right in saying, your suggestion was to disconnect the pipe either side and remove the whole tap then soak in vinegar and water.
DBop
DBop
53
26
I’ll do that, thanks again 👍
Campervan_man
997
1,720
Dethleffs Globebus
There are rubber 'O'ring seals inside that are squeezed when you tighten the drains.
Gradually they wear out.
Tease the OLD rubber O ring seal out, discard and replace with the exact sized NEW 'O' ring.
I fixed a dripping Hymer drain tap last year with the same issue.
DBop
DBop
53
26
I’ll replace the O rings, great advice and thanks.
I hear you Eggs, simplicity all the way 💪
DBop
DBop
53
26
Today I replaced both o rings on each drain down tap (4.5mm and 9mm diameter and 2mm thick were the sizes) folllwed by filling my fresh water tank. Post filling the tank I ran the water through the pipes with my eyes peeled on the drain down taps, so far no water has escaped 💪 Thanks campervan man. Cheers for everyone’s responses.
