Dometic fridge warm on ac in French alps (1 Viewer)
Aug 31, 2014
489
689
Surrey
Coach built
4th year
Hi,we have a problem with our fridge on 240v ac, since being in the French alps warm here at 30 degrees. The fridge will not go below 12 deg, freezer seems ok. I have tried it on gas and does seem to be getting a lot colder at around 7 deg, is this because the fridge runs better on gas?
I have taken the grill cover off for now and now have a fan running over the evap to help cool it all down time will tell. Has anyone else had this issue when we are in warmer climates?
Jan 19, 2014
9,395
24,785
Derbyshire
Elddis Accordo 105
since 2014
We had a similar issue, the fridge evaporator stopped frosting but the freezer was ok and both were a bit colder on gas. Turned out the heat transfer paste behind the fins needed renewing. Worked fine ever since.
Aug 4, 2013
1,140
140,227
Oop North
None now 😢
When it’s hot we switch to run ours on gas and try to shade van side with the awning, it does seem to work much better.
Charlie9038
Aug 31, 2014
489
689
Surrey
Coach built
4th year
Have taken the grill cover off for now & have a fan on the evaporator fins, already cooled by 2 degrees, in less than 1 hour seem to think these fridges struggle above 28 degrees on ac. Might fit a pc fan on the evaporators fins when I get back to the Uk, has anyone else tried this?
Jan 19, 2014
9,395
24,785
Derbyshire
Elddis Accordo 105
since 2014
Some do and seem to like it, but fan motors introduce heat themselves, you may think it's insignificant but commercial fridges get really hot inside due to the fans running when the plant fails.
Also I like the fact the bottom of the fridge is cooler and the top can be used for butter eggs etc.
Oh also. Important... the thermostat which is attached to the evaporator, is made to switch off at say minus 6°c. When you fit a fan on it, -6°c can never be achieved until the whole compartment is MINUS 6 :eek: (would never happen but it would use lots of gas trying:ROFLMAO:) . So in order to have any control of the temperature you would need to fit a bottle cooler stat in the return air.
Camping Gaza
993
1,467
La Châtre, Centre-Val de Loire France
Coachbuilt Low profile
Converted a Fiat Ducato PV a while back
Yes in central france when it hit 40c a few years ago. You need more airflow through the outside vents. Fit a fridge fan may help
Charlie9038
Aug 31, 2014
489
689
Surrey
Coach built
4th year
Sound perfect, where can I get these? Any ideas
53,454
150,116
Depends on the model the size of the heating element varies ours is 250 watt some are under 200.
I fitted 2 fans on the top grill and a fan inside the fridge.
11,842
14,071
I have two 5" computer fans in the top vent controlled by a controller from ebay. Around £15 for the lot. Works brilliantly though not silent. Some have wired the two fans in series thus slowing them and making them quieter.
