Dometic 3 way fridge freezer and oven
Garethjm
Fiat rapido 9096F
Hi all
Please help I haven't used my fridge freezer oven for 3 months but it was plugged in and on I had to move the camper so unplugged the mains moved the camper plugged the mains back in and the fridge only came back on for a min now nothing I have checked all the fuses I can find but still nothing no lights at all not for the fridge or oven and no spark either
Thank you
Gareth
hi welcome
its likely that the main fuse to the fridge is blown its probably in line near the main electro bloc or whatever system you have.
Hi thank you
I will have a look
Unlikely to be the fridge fuse if the oven doesn't work.
i must admit i missed the oven bit......:rolleyes:
is everything else working Garethjm ? and is it the oven spark igniter thats not working?
Hi Phill no nothing on the fridge or oven is working only the gas if turned on
Then you have tripped / blown a main fuse or trip somewhere.
I don't know your van but start at the habitation battery and work through the various connections to trace where the power stops and why.
It will take a bit of patience and being quite methodical but you will eventually get there.
In our van the same fuse supplies the fridge electronics & the oven ignitor.
In newer Hymers there is a fuse bank next to the EBL distribution unit that has fuses for items that require permanent power, the Fridge, Heating, Satellite, the fridge one is 2 amp.
I think I said something similar in post #2..
