does anyone out there..... (2 Viewers)
43,337
49,538
....fully understand, and can test & repair, electronics ?
i have a 20amp statpower (Xantrex) american charger which appears to have stopped working.
its not a current model so nowt on the web.
its been in the garage since removing it from the RV last november.
plugged it in to charge a car battery today and, without load, it light up showing it detected 'no battery'.
connected the battery, switched back on and NOWT ! no lights, no output.
checked the battery and it is very dead....Zero volts.
should have checked that first :Doh:
3 internal fuses..rev polarity, overload, short circuit....checked with multimeter and all ok.
230v getting to input .
may have been damp inside.
what i need is a techy to have a look at it and see if its repairable.
worth around £230 so dont want to scrap it.
anyone going to newark who could take it home and have a look please?
jhorsf
9,130
8,045
DERBYSHIRE
ih oregon
Before saying it is the charger try it on a battery that has some charge in it as it may not operate on a totally flat battery just a thought
43,337
49,538
worth a try i suppose but it did light up with no battery...sequence of leds indicate various problems...over/under voltage, no battery etc...but now it does nothing. :Sad:
dealgan
133
-1
Donegal, Ireland
since 2006
That may be the key. Is it an SMPS (switch mode power supply) or an old fashioned (but arguably better) linear power supply with a transformer, etc ?
Judging by it having indicators of fault conditions, I'd guess its a switch-mode, in which case I am of no further use !
Good luck.
43,337
49,538
Good luck.
yep...just electronics and two very small (20/25mm sq) transformers towards the back end of the board.
That's a switcher. Good when they work, only the maker stands much of a chance of repairing one. They are absolutely lethal things, rectified mains putting 340V DC on the pcb so a real specialists repair.
rainbow chasers
3,680
1,725
Mid Cornwall
Various
I cannot advise on that charger, as I have never met one in person - however, I did have a charger once that had a very similar quirk.
If cold or damp - it never wanted to play. Leave inside by a rad for an hour to warm and dry out and it would work perfectly. I did replace it in the end! lol!
Might be worth trying that.
43,337
49,538
its been in the house all last night and today and as a belt & braces exersize i got the cover off and got hair drier on it as well.
on the input side is a small glass 230v fuse in very close proximity to a heavy copper wire coil.....bit like a ferite ring.
so close in fact, it was arcing across from the 230v fuse end to this coil when i plugged in the power plug.
reckon its dead....what a waste. :Sad:
