Not a problem, if it needed draining down it would be in the operating manual.Ta for that the payload is not an issue just wondering if it’s ok and will not damage boiler or mounting by travelling full
Only drain boiler at end of season and it may be cold or when flushing system.Absolutely. Also travel everywhere with freshwater tank as full as possible as I never know where or when I'm stopping and might need it.
Why dump fresh water, only to fill up at the next location
I've never noticed any difference with 160kg of water onboard but our tank is amidships & low down.Only drain boiler at end of season and it may be cold or when flushing system.
Last few trips have had full fresh tank and the van appeared to be not as noisy and felt better!
After spending money on gas to heat it no way would I ditch precious hot water.If you do decide to drain the hot water, make sure you are not on a grass pitch, as it kills the grass and takes ages to grow back.
Geoff
I have never emptied the hot water tank in 10 years unless the outside temperature is likely to drop below 0*C
Thanks all for your reassurance! Will leave it full
When getting my system fixed at Alde, their engineer showed me a heater with the hot water jacket split (very expensive repair) and suggested that it is always a good idea to operate the dump valve for maybe 5-10 seconds every month or so to prevent hydraulic effects and ensure that there is an air gap at the top. I always drain down the fresh water if not using the van for a few weeks but only the whole system in the winterOnly ever drain ours down in the frosty weather.
If it did need draining down to prevent damage boiler or mounting by travelling full then it would not be fit for purpose in my eyes.
It’s part of the Alde instructions that you should drain the water heater every 4-5 weeks to allow a cushion of air at the top.When getting my system fixed at Alde, their engineer showed me a heater with the hot water jacket split (very expensive repair) and suggested that it is always a good idea to operate the dump valve for maybe 5-10 seconds every month or so to prevent hydraulic effects and ensure that there is an air gap at the top. I always drain down the fresh water if not using the van for a few weeks but only the whole system in the winter
Hi.If you do decide to drain the hot water, make sure you are not on a grass pitch, as it kills the grass and takes ages to grow back.
