Vanman
Ideally your power outlet to the habitation circuits should use positive C and negative A and use the same posts for your volt meter shunt.
This way both batteries are always getting an even discharge and charge as they are both connected evenly.
Yes in a car it's only so you don't short the positive lead to earth, not so important in a Motorhome where nearly everything is timber.Thanks, that's a good point. But as far as 'messing' with it just now, is it right to disconnect the x2 Negatives first and then reconnect them last afterwards?
To get totally accurate results then the shunt should be connected as o said earlier otherwise you will only read the condition of a single battery and that can be influenced by the second one.It looks like A might be the 'main' Negative after all. Do you think it will matter which I attach to the Shunt to take the readings from?
