Rabc
hi funsters any body had problems with their diesel heater i’ve got a autosleepers duetto and it’s only blowing cold air.
Mine did that.Needed a new circuit board.It was cheaper to buy a new heater.Hope yours isn't the same problemhi funsters any body had problems with their diesel heater i’ve got a autosleepers duetto and it’s only blowing cold air.
The most common problem is the glow plug fails.. They vary in price ( a lot ) but are an easy fix.hi funsters any body had problems with their diesel heater i’ve got a autosleepers duetto and it’s only blowing cold air.
Beat me to it. Lorry night heater would not work if less than 1/4 tank. we always diesel`d up before knocking off, so the timer would bring the heater on and warm the cab before start of shift. Neither would the Winnebago Generator fire up if the "gas" level was below 1/4.Make sure you have more than a quarter of a tank of diesel or wont work.
Just having one fitted. Do they take power from leisure batteries or engine battery?Also they need a lot of power to start, try it with the engine running
I think it would be the leisure battery, but if it's a new installation ask them. I wouldn't want it wired to the vehicle battery because is it is on overnight it could drain the batteryJust having one fitted. Do they take power from leisure batteries or engine battery?
Thanks you. That was my thought. They rang to say it will be ready this afternoon, so I will ring them first thing.I think it would be the leisure battery, but if it's a new installation ask them. I wouldn't want it wired to the vehicle battery because is it is on overnight it could drain the battery
As others have said, ensure that the voltage is good, try with the engine running. The minimum fuel level will be at what ever depth Autosleepers installed the feed pipe in your fuel tank.hi funsters any body had problems with their diesel heater i’ve got a autosleepers duetto and it’s only blowing cold air.
