toledo
Brand new diesel heater 5KW still boxed unopened £100 ono
These Classified Forums are now archived, so you cannot add to or edit them. Our New Classified System can be Found Here
The unit itself will get hot. Why someone would put it in the gas bottle store is beyond me
airhoguk. Because it was no longer in use perhaps? Our previous MH had 2 x 225v batteries in the "former" gas cylinder locker, due to it not being used as a result of an underslung bulk gas tank fitted.We met a chap whilst in Spain who had put one in his PVC in the gas bottle store which was located adjacent to the side sliding door (he had fitted an underslung LPG tank so it wasn't being used).
You are correct Jock, with the underslung tank all he had in the locker was the diesel heater which had one outlet hence why he had the melting issue. He'd quickly fitted it just before they went away on holiday and when the melting happened he extended the pipe to ensure it couldn't happen again, he said he was going to re-do it when he got home as there was nothing in the locker other than the heater so above it was just wasted space which he wanted to utilise.airhoguk. Because it was no longer in use perhaps?
No gas stored in it,,BUSBY.The unit itself will get hot. Why someone would put it in the gas bottle store is beyond me
Neither does mine & all I have on it at the moment is the 90º outlet. & that hasn't melted.My Chinese heater body itself doesn't get warm never mind hot nor does my directional outlet and that only has around 6inches of ducting from the end of the heater to the outlet. Yes the air coming out can be pretty hot depending on what setting I have it.
View attachment 367423View attachment 367425
