Design problem with my van? (2 Viewers)
May 7, 2016
7,260
11,748
West Sussex
Since 2003
I think of caravaners as the ones who put roots down with peg down awnings and lots of loose equipment to accommodate within it. I see motorhomes as being more mobile and principally designed for easy moving on. I do not want motorhome designers compromising on internal layout so that there are long blank walls without windows doors and vents, just in case one or two users might want to do something unusual like add a privacy room. I don’t even find the need for a wind out awning I just clip a sunshade to my chair.
Sorry but I am getting tired of hearing things described as poor design when it is simply a matter of the vehicle being designed for a different type of use. By all means modify it and the fittings you want to use, that is your choice but please stop blaming the design. Why should the rest of us compromise on internal layout, position of fittings, doors, hatches and windows etc. to allow for a fitting that most of us do not need or want.
Coolcats
5,940
9,942
HymerCar Ayres Rock
Totally agree, designing a MoHo must present challenges trying to meet core needs and then options....the list goes on and on..
Oh and the design issue is not the Van what is being described is the awning / privacy room supplier
R
Jan 21, 2020
257
163
Burstner
Everyone is entitled to their own opinion!
I am not attacking your opinion, you are entitled to it, as I am entitled to mine.
I agree there is some difference in usage between a motorhome and a caravan, however, in the time I had a caravan, most of the motorhomes I saw, never moved from one day to the next and a good proportion of them had an awning or enclosure of some description, so I feel my view is also justified.
John Barrett
1,963
15,246
Hamble, Southampton.
One Eyed in Hamble!
The one motorhome related post in yonks and it turns out to be an argument!
11,954
16,570
We're up to 93 (now 94) posts on this subject. Just think of the awning problem as a pleasant distraction from the sh*t construction (rather than design) standards reached by the leisure vehicle industry. And move on.
Oct 9, 2019
4,959
17,302
Todmorden
Van conversion
FUNSTER in a PVC
May sound a bit drastic but the door and it’s surround are one unit, could you not remove and refit with hitches to the rear of van and door handles to the front ? At least then you could open the door and it would just rest against your awning side pane. If you are not a diyer then there a number of mobile service engineers who could complete the job for you.
Coolcats
5,940
9,942
HymerCar Ayres Rock
Robster on a positive note in this image the tent is smaller than the van which would give clear access to the Garage, I suspect that this could be installed to the rear of the van giving access to the Garage (and venting of the Fridge), the only difference being no rear wall to the van but you can get draft strips for the lower part of the van which should help keep your dog in situ. It not perfect but as you have found none of the solutions are.
One other suggestion is if you want to have a good discussion with a very knowledgable supplier try Rose Awnings https://www.roseawnings.co.uk They are often at the MoHo Shows and from experience they have a wealth of knowledge why not give them a call.
53,453
150,101
My opinion too, Motorhome manufacturers are in business to make a profit so they produce what the market wants. Privacy room are propably used by less than 0.1% of owners not exactly a lot of people want then so why would a manufacturer go out of their way to produce something that is not required by the majority of their customers.
The OP should have done his research rather than buy something that is unsuitable for his use then bitch about it. A caravan would have been more suitable for him.
busbuddy
1,294
2,917
leicestershire
swift suntor 630G
since 1994
Just a thought where are your toilet waste access point and boiler vent? We had a Hobby and could not have a privacy room as it would have meant gassing us or removing the muck through the room. ( Good German design or what!) The continentals obviously do not use privacy rooms as much as the UK
I think you will find that a massive percentage of motorhome/caravans have the fridge/heater/boiler vent on
the habitation door side so would be inside any awning.
Coolcats
5,940
9,942
HymerCar Ayres Rock
Indeed just like the Thule photo
Jul 5, 2013
11,731
13,709
Well Bürstner designed the van, Bürstner installed the awning as a standard fitment in this position.
That in my book is a design fault By Bürstner, I have no issue with Thule, they cannot mandate how and where the awning is fitted, but someone at Bürstner should have realised this could/would be an issue.
I cannot see how you can blame Burstner or Thule.
It is an awning designed to be a sun shade and light rain shield for a motorhome not a caravan. Unlike the steel framed awnings used with caravans, it can't cope with winds or heavy rains because it is not designed to. Very few people people add a privacy room to their awning
Just looking at your motorhome, or even just a photo of it, before buying should have shown that this was not going to work for what you wanted to do. Most continental makers like Burstner list an awning as an optional extra, and most offer several different sizes to choose from. Many people choose the longest one, in which case a problem like this is inevitable because of that choice. If this was so important to you did you not check before buying that it would work with the length of awning you have?
Dan and Jan
572
4,524
Between Vans
On and off since 2000
On my 726g 55 the awning was positioned over the rear side window or garage door, so l decided to improvise by buying a Jormax windbreak and sometimes using a porch awning. Job done great van. (y)
Coolcats
5,940
9,942
HymerCar Ayres Rock
I cant tell you how many conversations I was having with the dealer when I ordered the Hymer, I must have drove them mad, and had at least 3 calls with Rose Awnings and a couple of conversations at the Show, I also contacted Thule who kindly sent and engineer drawing of the roof rails. Check, Check and check again......The sales guys are not technical and I had so many questions. in the end I understood 99% of what I was buying and received 99% of what I was expecting.....the 1% is something I can live with
R
Jan 21, 2020
257
163
Burstner
Hey Dan and Jan, I really like the look of the windbreaks you have, look like they would do the job a treat, can you point me at a manufacturer please or a link?
Silly question, but I notice in the picture you are on a heard standing, how easy was it to drive the poles into the ground or am i missing something?
32,662
66,580
He has to carry one of these ... :rofl:
Dan and Jan
572
4,524
Between Vans
Hi the windbreaks are by Jormax there are a few posts on here. They are really strong and stable. So far the posts have gone into any surface. Not cheap but are fool proof for dogs.
John Barrett
1,963
15,246
One Eyed in Hamble!
We have a Kampa windbreak at sensible money which also has base posts that are driven into the ground. I made some struts from gardening poles to eliminate the bits of string holding it up!
John
May 22, 2015
1,425
2,590
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
I’d personally go for a rain blocker and a front piece aswell, you can choose your length and which end you prefer to fit depending on weather etc.
The rain blocker will just pull out of the way to enable you to get in the garage. I had this same problem on my last Dethleffs but it didn’t worry me.
I also had a safari room but only used it a handful of times as the rain blocker and 1.5m front panel was ideal for us.
