Cooking on two gas rings, any hints, tips or recipes? (1 Viewer)
Vanman
1,666
3,924
Runcorn
Roadscout R PVC
March 2017
Still planning ahead to our new van and thinking of meals. We're not initially going for an External BBQ or microwave, oven or any heat source other than the two gas rings that come with the van (including Remoska!). We'll probably eat in pubs or have takeaways in the evening so it's only breakfast and a bit of lunch that we need to cover. Cold salads, cereal and sandwiches are an option, but it's nice to have something hot sometimes.
I'm thinking that a fried breakfast is probably not too hard to conjure up, especially if the meaty items are pre-cooked and just reheated in a pan and an egg or two added ... soup for lunch is a pretty obvious choice ... after that I'm struggling for ideas. Ideally they wouldn't cause too much splatter (can you still get splatter guards for frying pans?) or stink the van out for hours afterwards!
I've seen toasting racks that sit on gas rings and yesterday I saw some sort of sandwich toaster (it could have been a medieval torture device masquerading as a toaster though :) ). Any other cunning gadgets too?
53,686
150,943
No different to cooking at home on the gas burners although we have an oven in the van it's mainly used for par baked bread for breakfast.
For fatty things that spit a lot we use one of the cheap 10 quid gas rings outside.
movan
21,492
120,753
Moving around
Burstner
since07
Those steamers are handy in the mh .. the ones like a colinder that you place on top to steam the veg.. sorry not good at explaining. .
19,435
30,591
I'm with Lenny re cooking fatty stuff outside on the little cheap gas ring.
We don't have an oven and Mrs Funflair does lots of stuff on the gas rings a lot of which we have taken from home frozen.
BUT we have recently made a significant investment into the world of Remoska cooking, now there are a lot of gadget around the kitchen that really you just dont need BUT this one does actually work and you can have a whole meal without even lifting the lid on the gas hob, It does need 240 electric though, only about 2 amps.
I don't do cooking but I remembered something my Mum used to do in the AGA oven so thought I would try it in the Reloska.
Hash and Dash (dont know why its called that or if anybody else calls it that)
little balls of sausage meat, two or three eggs beaten with a little milk, tin of baked beans, a couple of tomatoes if you like but I forgot, chuck it all in the Remoska and gently stir but aim to keep the beans and the egg separate, put the lid on and switch on pour a glass of wine or two and 45 minutes later tea is ready serve with bread and butter if you fancy it.
19,435
30,591
Oh yes that something else we have and have used possibly once.
53,686
150,943
That reminds me we do have a small pressure cooker cheap €20 one picked up on Spanish supermarket.
Often when traveling prepair a meal during lunch time stop ready to cook at the end of the day. Only do it that way in winter try to avoid long drives in good weather.
Don't do bar-b-que's more to life than wasting hours burning meat.
19,435
30,591
I've updated my OP ;)
You could heat the take away up in a ------- oh your not getting one:xrofl:
You still won't starve though, Baked beans on toast, you can get wire mesh toaster things that go on the gas.
Floydster
1,072
2,773
Where ever I lay my hat
A lifetime
Note to anyone interested that off hook up using the inverter I reckon it uses about 50amps per hour for the large Remouska.
We use ours whilst on the move a lot (B2B charger), great to get to destination with the dinner cooked already.:xThumb:
14,778
76,377
Chilli's and curries are only two pot things, I make these a lot.
I also have a george foreman grill. This is great for breakfasts, burgers, steaks etc etc. Gives you plenty of time on the hob for the side stuff.
fish finger sandwiches currently being made :)
This is on my list for next year.
http://amzn.to/2hR48DD
movan
21,492
120,753
Moving around
Burstner
since07
Diablos are quite handy too for toasted snacks in a couple of minutes wfilled with cheese, egg, or beans ... on phone so cannot upload picture. Don't waste any bread .. don't forget to use the bits you cut off when you fill ..as the lining for the next one.
7,926
27,246
1992 VW Auto sleeper Mono
Since 2005 this time
There are a lot of 1 Pot recipes around, even on here if you can find em.
With a 2 burner try this
Pot #1 cook 500gms Tagatelli in slightly salted water until Al dente
Rinse and drain
Pot #2 slice 500 gms Mushrooms, Tsp Easy Garlic small glass white wine Chopped parsley to serve
Heat oil over medium heat, add mushrooms, cook for 2-3 min, add wine and garlic, cook till wine is almost evaporated, add pasta to mushroom&wine mix add parsley and season to taste, toss to combine & serve immediately
Serves 4-6
serve with a green salad and crusty bread
Adjust quantities to suit.
Cooking in M/H is not all Tins and beans on toast
18,045
48,201
If you can crack the toast making then scrambled or poached eggs on toast makes a good breakfast. And not too much washing up afterwards - something to consider if planning fry-ups.
You don't mention where you are going but if it is somewhere hot, salads and cold meats and cheese serve us for lunch more or less every day.
For cooking chicken bits etc in the evening in a hot country get a gas BBQ. With a big wide pan you can do paella on one too.
7,926
27,246
And here's another one
Grate raw potato (using a cheese grater) onto a tea towel, wring to rid moisture (this needs to be done immediately before cooking else the potato turns brown)
Heat oil in pan (slightly more than normal) form Shredded potato onto small patties, fry in oil until golden brown, turn to do other side.
As well as Potato patties in pan add Mushrooms minus stalk, and slice toms,
Season & Serve
I find the 3 slices of toms and 3 mushroom caps and 2 potato patties are sufficient for a light breakfast/brunch/lunch.
Kim H
547
1,709
Lancashire
Hymer S800
Since 2011
We don't have an oven in our van, by choice. We have 3 gas rings and a microwave that we rarely use, simply because we rarely use hook up. It was in our van when we bought it and will be removed when it fails. We have some friends that have recently bought a motorhome (tugged previously) and were insistent that they needed a full cooker, despite our best efforts to tell them otherwise - each to their own. On their first outing with us as 'virgin motorhomers' they decided it would be nice if we each cooked a meal over the weekend, a bit of a 'Come Dine With Me" - without the scorecards obviously :xThumb: So, we were duty bound to show what could be cooked without an oven. We made paprika pork with spiced lentils, carrot, onion & garlic and other seasonings. They were astounded at the flavours that could be created with 2 gas rings - btw we have a double skillet that we used to cook the pork :xwink:
412
742
derbyshire
Autocruise stargazer
since 2013
Stir fry in a wok/frying pan with noodles is a very easy one pot dish. I also give my vote for the George Foreman grill. We have used ours loads both inside and out - just remember the extension lead.
Allan & Loren
1,736
2,630
Leyland, Lancashire
Autotrail Dakota
Since 2014
Sandwich toasting bags are great. They are designed to work in a toaster but I use them in a griddle pan in a low heat and they work really well. I also use them to reheat croissants.
Alternative to a cooked breakfast is drop pancakes with whatever topping you like. We like fresh fruit, yoghurt and a drizzle of honey.
Vanman
Vanman
1,666
3,924
Runcorn
Roadscout R PVC
March 2017
So that will work on a gas grill then? xroll:
Stir fry in a wok is a good plan though, rice boils nicely on a ring too :xThumb:
2,107
10,269
Grantham
Rapido Le Randonneur
Tinned tomatoes heated, stir in grated cheese, melt. Dunk in fresh bread...good lunch menu.
Cut up salami, into a frying pan, add tinned tomatoes, tin baked beans, bouquet garni, tin of water. On other hob cook some pasta. Mix the two together for a very quick tasty meal.
For breakfast, what about French/ Gypsy toast? Beat egg and milk together, put slice of bread in the egg mixture, then fry in a pan. Nice with fruit compote, or sprinkled with sugar.
Cut bacon into pieces, fry, add sliced, cooked potatoes, grated cheese. Delicious. Easy. Nice with salad.
I could go on! :xgrin:
movan
21,492
120,753
Moving around
Burstner
since07
Season & Serve
You can add grated cheese to the grated potato too. And if you don't want to do individual pates .. do it in one .. like a pancake ...turn over ...
Can do all sorts of variations .. top with slices of cooked tomatoes slices of onions black pepper Worcester sauce ... and slice up like a pie. This prob works better if you had an oven to put in for 10 mins but I have worked round that on the hob.
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
We cook pretty much everything you would at home except for breakfast and fish. Can't stand the stench in the MH.
We use hot plates, oven and remoska.
Outdoors? Anything goes especially fish on hotplate or Cadac grill.
The grill on our oven is pointless, like a grill in a 70s camper!
CWH
5,155
247,971
WildAx PVC
From November 2013
Eggy bread/ French toast
Omelettes - ordinary UK style, with whatever filling/ topping you have available, or Spanish potato style
If you can do soup, you can do stew
Any pasta, with any sauce
Any rice with any accompaniment
Salads - cold or warm - be adventurous! - they don't have to be "rabbit food"
Fresh veg - boil or, for preference, steam (less steam into the atmosphere than boiling)
Well... anything you could do on a ring at home really!
Avoid frying
Avoid fish
Avoid burning anything
Open a window
