SandraL
- Jan 24, 2012
- 1,373
- 985
- Hymer b694sl
- Since 2012 + Caravanner for 20+ years
We have now coverted 2 bikes.
First was with a Bafang motor. Hardest part of conversion was removing existing pedals,arms and bottom bracket.
Some heat, extractor, hammer and wedge were involved here!
Assembly of motor into bottom bracket was straight forward. As this motor was fitted to a recumbent trike we had to stop motor rotating under heavy load, added wedge of wood to stop this . Fitted battery to existing rear rack.
Had to change brake levers with those in kit that have cutout switches for the motor when braking.
Second was a Tongsheng kit. Fitting was similar but as it senses pedal pressure the brake cutouts are not required, but were supplied in the kit.
The Bafang will add motor power as long as the pedals are moving. It powers to a set speed no matter how slow you pedal. These speeds increase as you increase the power setting on the screen. You can add a gear change button to cut power as you change gear which is kinder to the gear mechanism. Operating the brake gently would have the same effect.
The Tongsheng motor works when it senses effort on the pedals. The more effort the more help you get.
This means you can ride at any speed, useful to match others riding as a group rather than power on, off etc with the Bafang.
Only fitted this one today so not yet been anywhere on it. In the screen menu you can alter the pedal effort needed before assistance is given.
We have both got the same 48v 12.5ah battery. Idea being we can swap should one ( hers) run low.
Also intend to get dc dc buck converter with output set to around 12.5v. Idea being to use bike battery to assist the van leisure batteries should we run low, ie to take the load rather than charge the leisure battery.
Cost. Battery £190 each, motors £300 ish, Tongsheng tsdz2 slightly less Bafang bbs02 soughtly more.
Only other expense a set of wheels and tubes and a chain for my bike, couldnt get the freewheel off and wanted new cassette as teeth were knackered.
If you are reasonably handy then perfectly doable. Worst bit is extracting existing cranks and bottom bracket. Wiring is plug and play except possibly battery wiring depending on its location.
