specific gravity = 1.265 - 1.280 At 26C
That's OK with open lead acid, but how many have these.
I thought most leisure batteries were either AGM or Gel batteries. How would these be affected I wonder. Also, 250 cycles does not sound a lot? Mine are quoted at 1000 and there only mid range AGM batteries. (Now discontinued).
Me, Me, Me
This all makes perfect sense but in most cases imperfect charging whilst on site isn't too long term? Once the van is back home & hooked-up the (modern) van charger will operate its boost cycle and give the batteries the full charge they need. Even on the road the alternator, whilst not running long enough to fully charge the leisure battery, will at least charge at a reasonably high current. The A2B or B2B systems will do the same even more effectively.The scenario you had Alan, was that the batteries were partially discharged then recharged fully.
It is not the shallow depth of discharge that causes lead acid battery sulphation but the failure to completely recharge.
You are right in saying that you can discharge a lead acid battery any amount (but not beyond 100%) and no 'memory effect' or sulphation takes place.
Its the full recharge that is critical.
It's worse than that: two gases are produced (hydrogen and oxygen) in perfect proportions to explode and produce ................ water. There have been a number of industrial accidents over the years caused by sparks from connecting / disconnecting batteries.The gas produced is hydrogen which in some specific concentrations with oxygen (air) can be explosive.
I do feel sorry for new mh owners reading these type of threads....bless them if they were not confused before they are now...
......... sometimes I'm glad I'm thick.. I don't understand any of this ..... it would only give me something else to worry about if I did..
Me too.Me, Me, Me
Very interesting this thread and I am slowly trying to assimilate the info contained within it. When at home I keep the moho on 240v permanently, is this wrong/dangerous. The van has solar but it's kept in my barn. Is there a foolproof way of testing the condition of the batteries (Leisure and vehicle) and also of knowing if the batteries are fully charged.
bumpGreat thread Jon and I have a little question......can you over charge a battery? Say you left it on charge for 3 days as opposed to 16hrs
