clutch slip (2 Viewers)
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
stink etc.
i once had to back up a slope with the clutch slipping ! it smelt like an abbatoir on fire ! next day, and since (2 years) it has been fine, if it aint broke dont fix it !:thumb:
Digger Driver
578
4
Lancashire
:whatthe:
hi put y did it slip in the first place
Clutches are very similar to brakes!
Excessive use of brakes can cause brake fade where th disc gets so hot that they no longer work!
The same thing could have happened to your clutch!
The foolproof way to check a slipping clutch is to put it in fourth gear with the handbrake on then rev the engine and let the clutch out slowly if the motor stalls the clutch should be fine!
If the engine still runs you need a new clutch!
11,843
14,080
Would suggest if you try the test as per Digger driver, you keep the footbrake down as well, otherwise you might find the clutch is fine but the handbrake is kn***ered:ROFLMAO:
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Good point there, BUT have you got THREE FEET!
One for the GAS
One for the footbrake
One for the Clutch:ROFLMAO::ROFLMAO::ROFLMAO:
