Clutch Claw With 10% Motorhome Fun Discount Code
Wombles
11,358
12,303
SW England
Van Conversion
A few years now
The Clutch Claw is a barrier security product that we have used on both our motorhomes & cars for many years & as it's a popular product with Funsters we now have our own Fun 10% discount code motorhomefun10 when buying direct from the manufacturers website
https://www.nkgroup.co.uk/product/clutch-claw-in-car-security-device which makes it £95.10 delivered instead of £105 (y)
Should have spotted this before (it's in the Clearance section) but for anyone who doesn't mind the odd paint imperfection on your Clutch Claw there is some Grade B stock https://www.nkgroup.co.uk/product/clutch-claw-car-security-device-grade-b/ which using the discount code are just £86.10 delivered but stocks may be very limited (showing 3 now) so be quick if you want one! :cycle:
T
The discount not working now ?
T
Hi - just did a dummy order & code motorhomefun10 took £9.90 off - maybe you have a space at the beginning, used letter o in stead of 0 (zero) or mistyped? I know to suggest these as I've done all these before! :blusher:
Ok I have a go again thank you for looking very kind of you
Thought I would add, keep the pad on the bottom so as not too scuff carpet/flooring. When pushing top section in before locking push pedals down a bit so you can get as tight a fit as possible. There is a U-Tube tutorial video for fitting and it's easy to follow. Looks like a good bit of kit.
Ordered a Clutch Claw yesterday and the motorhomefun10 discount code would not work for me. However a discount code kindly supplied by Wombles some months ago surprisingly did still work and gave me a 10% discount. Well pleased with this, so thank you to Wombles and to the
NK group. All I need now is the motorhome to fit it on ! 😉
Hi - glad you got some discount (y) & thank you for letting us know.
Just did a dummy order & Fun code motorhomefun10 worked so maybe there was a space it didn't like (discount code boxes are notoriously fussy!) or a glitch but all good now. Hope you like it & get your motorhome soon :smiley:
Thank you for the code, it worked fine for me.
Not sure if it helps but my ipad always wants to put the first letter in Capitals, which the code does not have.
Thank you again.
Thank you again.
Good to hear that :smiley: That tip may be helpful to some too (y)
There is some Grade B stock now but the discount code now only works on the full price :(
UPDATE: The Fun discount code has expired but will contact the manufacturer to see if we can have a new one 🤞- in the meantime if you sign up for their newsletter on the pop up on the webpage https://www.noisekillers.co.uk/coll...products/centinel-clutch-claw-security-device then 10% discount off your first order.
Still have our two ancient Clutch Claws in daily use on both car & motorhome - great advantage has been that they can be adjusted rather than replaced when changing vehicle so a good investment.
There are several models of Clutch Claw now - please note that for the Fiat Ducato/ Peugeot Boxer version "The only difference is the length of the centre bar is shorter on the Fiat Ducato version due to the tight space it has to fit in" Hope that helps some on here.
Very good live chat on the website (thank you Dan (y)) - new 10% discount code already - MotorhomefunNK10 taking any model of Clutch Claw down to £126 delivered.
